| General Scanning Forum General forum for the discussion of radio communications related information, including discussion regarding scanners and radio receivers. Location specific posts should be directed to the regional forums listed below. |
09-21-2004, 11:12 AM
WIN96 and The PRO2096 - Extended Frequencies Unlock?
Since the manual states that the PRO-96 can be cloned with the PRO-2096, can we assume that WIN96 works with the new 2096?
Also, can we assume that this also goes for the "extended frequencies" ability?
Mr. Starr - any comments?
73's
KD4YGG
"Have A Nice Day"
09-21-2004, 11:16 AM
Location: Going to college in Waterbury, CT. But still a Baltimorean at heart.
Can't remeber for sure, but I think I asked the same question some time ago. And the answer I believe was, yes it can.
09-21-2004, 11:54 AM
Re: WIN96 and The PRO2096 - Extended Frequencies Unlock?
While I'd have to actually test Win96 with a 2096 to be sure, I believe all features will work.
There might be some minor changes to Win96 to support differences between the 96 and 2096. For example, the backlight functionality looks different.
-Don
09-21-2004, 02:30 PM
*In theory* and I have requested to my DM and Fort Worth to be the first on the block to recieve this scanner when it becomes available and since we out sell almost every store in scanner volume I'd like to think it will happen.....
I will test the scanner out as soon as I get it and post the results here.
Michael
KE7ENC
BC246T, BC996T, ICOM 2720H, ICOM T90
I like reality radio over reality TV shows. I am not a scannerhead, I just like to listen.
09-21-2004, 03:34 PM
This is from the WIN96 website:
Win96 is a software program for the Radio Shack PRO-96 Digital Trunking Scanner (as well as the forthcoming PRO-2096 "mobile" version).
So there's your answer regarding compatibility!
09-21-2004, 05:16 PM
Moderator
Hmm, I think I will take Don's comment above before I believe what he wrote on the his site before he gets his hands on a unit to test.
A little off topic, is there some reason everything you post on this site is in bold face?. It is just a little aggravating IMO. :?
09-21-2004, 11:19 PM
Ditto. I'll take the word of the software author on the capabilities of a piece of software over some site webmaster any day.
Joe M.
09-22-2004, 12:31 AM
I certainly didn't mean to offend anyone's sensitivities by using bold on here. Not sure why it does, but I can cease and desist.
I agree that Don's earlier statement on the website was likely based in good faith on what he was told about the 2096, and that some fine tuning will need to be made for full compatibility once he has the final product in hand. Unfortunately I posted that statement before I saw Don's comment above (just missed it), or I either wouldn't have made the post, or made it differently.
09-22-2004, 12:56 AM
Which site webmaster?
09-22-2004, 01:12 AM
You know the WIN96 webmaster.
Apparently someone has missed the connection and others are stringing this along.
Michael
KE7ENC
09-22-2004, 08:40 AM
aaahheemmm, I have a sneeky suspicion, Don is the webmaster in question.........
09-22-2004, 09:45 AM
By golly Mo, I think you may be on to something there!!!!!!!!!
09-22-2004, 02:29 PM
OK, then Don is saying one thing on the web site and another on here? :?
Then again, the website doesn't actually CONFIRM that the two are 100% compatible. There may be some tweeks needed.
Also, I read that site as the PRO96 website, not the Win96 website. My bad.  ops: [In my defense, there is only a Win96 web PAGE, not a web SITE - Win96.com, .net, or .org, for example, doesn't exist. Well, the first two do, but not for the Win96 software!]
I would still take Don's word over anyone else's as to the capabilities of his software.
Joe M.
09-22-2004, 02:41 PM
Sort of. Don said on his web site (quite some time ago), that Win96 would work with the rumored PRO-2096. I will still stand by that assertion.
However, there are minor differences between the operation of a PRO-96 and PRO-2096 - see the backlight example I cited earlier. Such differences may require minor "tweaks" to Win96.
Keep in mind that the PRO-96 and PRO-2096 are "clone compatible". From the PRO-2096 manual on the FCC site: This scanner can send/receive the data to or from a PRO-96 scanner. But Right [ed: this should probably read "Bright"] (PRO-96) and Dimmer (PRO-2096) setting does not transfer. There are to set the default setting. Since Win96 uses the scanners' "clone mode" to transfer data, if it's compatible with one it's compatible with the other.
Good idea  . However, I don't know that anyone else has yet described the capabilities of my software. They've quoted me, but haven't offered their own, original opinions.
-Don
09-22-2004, 03:02 PM
So does this mean we should expect a new version of Win96 once you get your hands on the 2096 and play around?
09-22-2004, 03:07 PM
Maybe... maybe not. It depends on whether there are differences between the two that can be addressed by Win96. The only difference I've seen, so far, is the backlight. But the text I quoted above says that's not transferred (you get default settings). We know the backlight info is transferred between two 96s, so we'd have to see what happens between two 2096s, or between a 96 and a 2096.
-Don
09-22-2004, 03:10 PM
Gotcha, I'll be waiting patiently, trying hard to control my breathing
09-22-2004, 03:30 PM
Win92,Win93,Win95 & Win96 can do everything you can do with just your scanner plus some. From opening up additional frequencies to allowing you to back-up/restore configurations and for the non-V-scanner units combined with a PC and preferably a laptop for portability gives unlimited V-scanner-like operation. The user interface is sleek and well thought out. No manual is really necessary to use the software and by using the software you get a immediate undersatnding of how your scanner is laid out. Once you use the Winxx products you'll never go back. Highly recommended and well worth every penny.
Michael
KE7ENC
