pepperpot
- Joined
- Mar 18, 2004
- Messages
- 43
See cg's April 10 post re a similar problem. Recently bought a Linksys WRT54G 2.4Ghz network router for the main home computer. Then found that on my Pro-96 I had a problem with scanning the county Motorola 800Mhz digital system in the same room as the router. Unless I hit Pause on an active TG, the scan got stuck on 154.2200 simplex with just noise. When I was far away from the router, no problem. I read the discussion and solutions in the April 10 post, then came up with a poor man's solution. Went out to the kitchen and got some aluminum foil. Made sort of a cradle around the one side of the scanner in effect blocking the router signal. It works and I can scan and surf at the same time again.
