Go Back   The RadioReference.com Forums > Scanners and Receivers Forums > General Scanning Forum
General Scanning Forum General forum for the discussion of radio communications related information, including discussion regarding scanners and radio receivers. Location specific posts should be directed to the regional forums listed below.
Old 10-22-2004, 04:37 PM
TexasQuad's Avatar
Default Pro 2052
Hi Yall,
Will the Pro 2052 follow specific conversations without being interrupted by school bus conversations and such.
I want to only listen to my towns police calls on 800 mhz without interruptions from non specific other groups.
Thanks, Scott
Old 10-22-2004, 05:06 PM
fmon's Avatar
Default Re: Pro 2052
Originally Posted by TexasQuad
Hi Yall,
Thanks, Scott
You can set your scanner up with the PD ID's in the five Scan List then use SCAN not SEARCH. Each list has space for 10 ID's and only those programmed will be scanned. BTW if you see - - - - - instead of SCAN on the display, you are in ID SEARCH, if so, Press SCAN. BTW, you will need to press the number 1 through 5 during ID SCAN to select the list(s) which have your ID's programmed. Those numbers will appear at the top of your display.
Frank
RR Wiki Programming Shortcuts
Old 10-22-2004, 05:40 PM
TexasQuad's Avatar
I dont have the scanner yet. I just dont want to make a mistake and get a scanner that wont follow specific conversions. I have a Pro 2030 and am plaged with all sorts of junk on 800 to interfer with the calls I want.
Thanks, Scott
Old 10-22-2004, 05:56 PM
fmon's Avatar
How many Police and fire TG's do you have for the system?
Frank
Old 10-22-2004, 07:26 PM
The Pro-2052 is a very good scanner. I monitor just the Fire Department on our local EDACS system, which has 11 frequencies and hundreds of various talkgroups. Once programmed, you can set it to monitor only the talkgroups you want to follow.
Scanning Since 1971
Current Scanners: Pro92, 94, 97, 2050, 2052, 2004, BC-200XLT
Antique Scanners: TMR-8H, ACT-R10H/L/U, ACT-W10, ACT-A4W
Ham Radio Since 1975 - VE for ARRL, W5YI & WCARS
