Go Back   The RadioReference.com Forums > Scanners and Receivers Forums > General Scanning Forum
General Scanning Forum General forum for the discussion of radio communications related information, including discussion regarding scanners and radio receivers. Location specific posts should be directed to the regional forums listed below.
Old 12-12-2004, 01:58 PM
dynamitedjs's Avatar
Default What is this?
What is this?
http://www.radioshack.com/product.as...%5Fid=940-0685
and what exactly can I do with it?
Old 12-12-2004, 04:33 PM
Spleen's Avatar
Send a message via ICQ to Spleen Send a message via AIM to Spleen Send a message via MSN to Spleen Send a message via Yahoo to Spleen
A little better description is here:
http://www.vectronics.com/products.php?prodid=VEC-1613
The actual hardware plugs between your radio and the serial interface on your PC.
You can grab JVFAX here:
http://www.pervisell.com/ham/downloa...VFAX Version 7
The actual HAMCOMM software is no longer supported but is still available to play with. Nowadays, most decoding is done by the sound card, so you probably want JVCOMM32 or a similar package (MMSSTV, Weather Fax 2000, etc.)
Try here for a decent list of available packages for all kinds of decoding modes:
http://www.g3vfp.org/download.html
A premier site about weather fax software and decoding is here:
http://www.hffax.de
Bottom line, the product is usable, but considered legacy, as 99% of all decoding packages out there now employ the sound card via a direct connection from the radio to the LINE IN, and there are plenty of free or open source packages available...you shouldn't have to spend a dime other than the PC and receiver you already have, unless you really get into decoding and have to buy another radio to cover the frequencies/protocols you want to receive/decode.
Fer instance, I got into weather fax decoding because I used to have to do it the old-fashioned way when I was but a lowly airman trying to pick up the European fax broadcasts in order to have some sort of data to give to the forecasters while we were on exercises...in all those years, it really hasn't changed that much, except now you can do it at home with a PC and a HF receiver.
