namiezbud said:I am so confused, got a scanner for Christmas and I am used to conventional scanning. Are there any references that explain how to scan using trunked systems?
crawford330 said:I'm with you namiezbud......I've been trying to figure out this trunking stuff for several months now. I just found this website and forum yesterday. There is a lot of good information here but I'm afraid most of it goes over my head. I still am not getting my scanner to pick up anything from a trunking system.
Signed,
C330
Crawford County, Arkansas
Scanner: PRO97
Now THAT is funny.jonny290 said:TRUNKING FOR DUMMIES:
A small town has five gangs of youths in town. When they built the corner diner, they only put three booths in there, as there was no need for more....
...Each "gang" in a trunking system is called a talkgroup. each radio 'joins a gang' and does whatever that gang does. Each "booth" in a trunking system is a channel (or frequency). Every time a radio keys up, the 'waitress' tells everybody in that 'gang' what 'booth' to go to this time.
Signed,
C330
Scanner: PRO97
n2mdk said:What trunking system are you trying to listen to? If it's Arkansas Wireless Information Network (AWIN) that's digital and can't be listened to with a Pro-97
crawford330 said:Ok, apparently I have my sources wrong because this site clearly does not list EDACS for the state police but I did find that information somewhere and it is apparently incorrect.
Can anyone recommend a scanner or radio for AWIN?
C330
n2mdk said:Lets start with the system I know will work in the Pro-97 this one
http://www.radioreference.com/apps/db/?sid=2241
You will see it has 4 sites listed, each one needs to be in it's own bank starting with a channel number of 001, 101, 201, 301. The mode has to be set to ED for EDACS the little gray numbers next to the frequencies are the LCN order (channels) that each frequency must go into.
dbsar said:Crawford 330. 99. I feel your pain.
If this helps, I program my pro 97 this way. Bank one is my county, bank two is neighboring county... Within bank one, I program in all the listed frequency numbers making sure to tell the scanner what type of system these frequencies are (EDACS MOT etc). Once you enter all those frequencies, you must now tell the scanner what departments you want to listen too (or you can listen to every department who uses the same radio system). My scanner calls these sub banks. I enter the talkgroup id number and then type in the name for the talkgroup (i.e. LAPD DISP 1) . Now the scanner will monitor those frequencies in the selected banks. If you tell the scanner to limit what you hear to the departments in your sub banks, it's a lot eaiser to follow.
