| General Scanning Forum General forum for the discussion of radio communications related information, including discussion regarding scanners and radio receivers. Location specific posts should be directed to the regional forums listed below. |
01-02-2008, 09:57 PM
Programming with Multiple Sites
Allrighty, so I've read the Wiki about what a "site" within a trunked system is, now I just need to understand how to program this. Several of the systems which I want to program have multiple sites. One in particular system which I want to program has 9 sites, two of which are simulcast, and one which is listed as a non-trunked site. All of the sites are fairly local and this will be used in a mobile system anyway. Question is:
Can I program all the frequencies for all the sites within the system in one bank? or Do I need to treat each of these sites as a separate trunked system, and program them in their own bank?
Also, what do I do with a "non-trunked" site? I'm assuming that I would just program this in as I would a normal VHF/UHF channel.
I am using a RS Pro-433 and a Pro-94. Thank you!
01-02-2008, 10:20 PM
In response to my own question, I found some unexpected answers in the control channel only tutorial. While my RS Pro-433 does support CCO programming, the system I'm trying to program doesn't fall in to any of the 4 plans (the combination of the last 3 digits doesn't fit any of the 4 plans), so I'm assuming that I'll have to program all of the channels for each site with the dummy channel in between, correct?
Also question regarding the site which is labeled "non-trunked" still stands...
Thanks guys.
01-02-2008, 10:24 PM
It would help if we knew exactly what the system your talking about was.
Jerri
VX-5
FT-60R
Pro-97
BC246T
BC780XLT
BR330T
BCT15
Grundig Satellit 700
01-02-2008, 10:34 PM
Well, one particular system which I want to program is the Orange County, FL system. However, this question will apply to other systems I am interested in programming when I travel, so I thought a general question was in order. I checked the Florida section, however someone asked a similar question about the Orange County/Orlando system, with not much of a response, so I thought I'd pose it more generally here. Sorry! =)
01-02-2008, 11:05 PM
With the scanners you mention each site will have to go into a seperate bank. I'm assuming your talking about one of these 2 systems, actually they look to be the same with different/conflicting info about each http://www.radioreference.com/apps/db/?sid=205 shows it of be a mixed analog and digital while this http://www.radioreference.com/apps/db/?sid=5393 seems to show the same frequencies but as purely digital.
Jerri
VX-5
FT-60R
Pro-97
BC246T
BC780XLT
BR330T
BCT15
01-02-2008, 11:19 PM
N2,
Yeah, that's what I'm talking about. It seems that the majority of traffic is simulcast on the Orange County site, so just programming in that system should suffice, but I think I'm going to miss out on some traffic for a few of the cities without the other sites. Several of them are digital and encrypted so it's not an issue, but I just don't want to take up 9 of my 10 banks with this one system. I'm also interested in programming the system for Volusia County, but it seems I'm going to end up with the same issue with 1 system with numerous sites, and no place to put it all. Thank you for your help again.
01-03-2008, 05:50 PM
Originally Posted by PearlOnyx
N2,
Those other sites are probably Intellirepeater sites for "fill-in" in difficult areas. Only units affiliated to those sites use them. The "County" and "Orlando" sites, one in each bank, should let you hear everything.
01-03-2008, 09:15 PM
Dick,
Yes, that is true for the most part. While most of the city system is simulcast on the county system, from a little research it appears some of the city ID's are only broadcast on the city system. There is a similar issue with Brevard and Volusia Counties. I spent some time fiddling with my set up, and I've got most of what I want programmed in to the software. Just waiting on the cable to come now =) Thank you for your help.
