Go Back   The RadioReference.com Forums > Scanners and Receivers Forums > General Scanning Forum
General Scanning Forum General forum for the discussion of radio communications related information, including discussion regarding scanners and radio receivers. Location specific posts should be directed to the regional forums listed below.
Old 01-13-2008, 01:18 PM
Default On/Off?-That is the question.
Hi All -
Do you leave your scanners on all the time (plugged in of course), or when you are away, do you turn them off?
I listen to an old sportcat SC150 (mainly at night) that's hooked up to my Boston Receptor Clock Radio (sounds great) and it is easier to just turn off the Boston and leave the scanner running.
Let me know what you all do.
Thanks,
Old 01-13-2008, 01:23 PM
Off... I hate supporting the electric companies at 17 cent per kilowatt
Canada or bust!
I will only respond to negative comments/feedback. Friendly people will be ignored totally.
Old 01-13-2008, 01:27 PM
Dubbin's Avatar
The only one I leave on is a PRO-2067 since it is used for my live feed.
Dwayne
My Scanner Feed
Old 01-13-2008, 01:30 PM
Raven95150's Avatar
No reason to leave it on if you arent using it. Most of our wasted energy (and part of the reason for increasing energy costs) comes from leaving devices turned on when they are not being used.
KD0AXS
Metro Skywarn #7344
Uniden BCD396T, BC250D, BC350A
RS PRO-84
Yaesu FT-2800M, VX-170
Old 01-13-2008, 01:32 PM
bravo14's Avatar
Send a message via AIM to bravo14 Send a message via Yahoo to bravo14
When I am out of town for a day or so I unplug it case a bad storm rolls in. Most of the time it stays on 24/7. I do turn it off sometimes and just use of my hand held to RX Fire.
Dude you got jail, you can't get a dell.
Flickr Site
Old 01-13-2008, 01:42 PM
On.
At 7.3 cents per kWh, my PSR-600 costs about $1.60 per month (presuming the max 30W of the power supply).
Old 01-13-2008, 01:47 PM
To clarify, I know it wastes a bit of electricity, but can you do more damage turning the unit on and off daily or leaving it on for the long haul.
Old 01-13-2008, 02:41 PM
captclint's Avatar
This question has no definitive answer. As a reliability Engineer for an electronics company, it was my job to find trends that would shorten the life, and help to find ways to reduce the risk. One of the best tests we had was called: Power Cycle. We would power units on and off for thousands of cycles, and there is no question that this eventually causes failures, usually from solder joint fatique. However, in the context of the life of well designed products which been designed to minimize this effect, you rarely will cause unit to fail in the short time you will use it. By short, I mean 5-10 years. (on/off twice/day for 10 years=7300 cycles) Most well designed and tested products will last longer than that.
So my answer would be: 6 of one and half dozen of another for scanners, since they don't generate a lot of heat except in the battery area. Vacumn tubes used to fail if they were left on for a long time, but semiconductors do not.
Regards,
Clint Chamberlin
Luzerne County, PA
Old 01-13-2008, 03:41 PM
Bentley's Avatar
I always turn mine off when not in use. Although, I have an old(er) RS pro-2048 at work and its on 24/7 for the past several years.
BNN Dispatcher - NJC-4246
My Photos: www.code3.photoreflect.com
Old 01-13-2008, 03:44 PM
I should probably qualify my above "On." response... I do turn my PSR-600 "off" when it's not in use. However, it's "in use" nearly all of the time... streaming, recording locally, etc.
Old 01-13-2008, 07:31 PM
Post
All 5 of mine stay on 24 7 365.
Old 01-13-2008, 07:39 PM
LordJ's Avatar
Send a message via MSN to LordJ
ON, just like my computer....
Just because I can, doesn't mean I will. (But I might)
Old 01-13-2008, 08:14 PM
n9zek's Avatar
Send a message via AIM to n9zek Send a message via Yahoo to n9zek
I turn off the Ham Radio base when I not at it. The scanners stay on 24/7/365.
Preparedness is not an option!
http://stores.ebay.com/PERSONAL-SAFETY-SECURITY-STORE
Old 01-13-2008, 11:33 PM
Smile sc150
I have an sc150y that runs continuosly, I do unplug it when I will be gone for a couple of days because at times it has gotten warm. I had to replace the ac adapter recepticle where it got hot, don't know if this was from charging or poor or dirty contacts on the plug. This will also ruin a nicad battery which might also run warm from constantly being charged. I leave it on at night so I can leave my mobile home when the weather gets really bad. The local PD gets very active during bad weather and I am usually awakened by the chatter. I also listen to the emergency channels, if there has been a tornado or major accident I sometimes get called to clean up debri and repair the roadway and it never hurts to be aware of what has happened before going out. kfred
Old 01-14-2008, 02:16 AM
kb2vxa's Avatar
Why "use" anything when you're not using it? Such foolishness makes no sense at all.
73 de Warren
Amateur Radio KB2VXA
Station powered by atomic energy, operator powered by natural gas.
Old 01-15-2008, 12:48 AM
For those of you who are saying that you leave devices on because they cost so little to operate, you are forgetting that the cost does add up over time. Even if it only costs you one measly extra dollar per month, that's twelve dollars per year. And let's suppose you have three things that you don't turn off; that's $36 per year. Not a huge amount of money, but still, that's $36 that you could have spent on something else. Also, you forget that we are very rapidly depleting our natural resources, including the ones we use to generate electricity. One device may not make a difference in the grand scheme of things, but we have to start somewhere.
Old 01-16-2008, 01:03 AM
I doubt it uses anywhere near that. If it did, you'd feel the heat.
Old 01-16-2008, 01:12 AM
If you really want to save money or the environment, drive a fuel efficient car, carpool, give up smoking, tweak your thermostat, stop buying coffee at the drive through, etc. Worrying about scanner current consumption is a waste of time by comparison. You'd save more money by skipping one night out with your drinking buddies.
Old 01-16-2008, 05:10 AM
kb2vxa's Avatar
Just think, saving all that money adds up to a lot of beer. Now if you want to save the environment support your local watering hole. Save water, recycle!
73 de Warren
Old 01-16-2008, 05:34 AM
Austin4Wyo's Avatar
Or drink beer
Similar Threads
Whip Antenna Question njt462 Antennas and Coax Forum 15 02-14-2009 11:58 AM
Another newbie question - BR330T Quick Keys scrosby2 Scanner Programming Software 5 08-28-2007 12:50 PM
Repeater Question cookiend15 New York Radio Discussion Forum 5 06-25-2007 11:53 AM
prepurchase research question powerhouse HF/MW/LW General Discussion 5 03-04-2007 10:04 AM
Manual programming question manross Radio Shack Scanners 2 01-10-2007 09:31 PM
