Thanks for the info in this thread. My Pro-96 suffered a failure a couple of weeks ago when the conductor from the telescoping antenna broke off in the BNC connector. In trying to get the conductor, which broke off flush with the BNC connector dielectric, out, I broke the rigid wire connecting the antenna jack to the motherboard. I got that fixed, but still couldn't pick anything up. Then I opened the bank and realized that the digital swapover had occurred.
I am picking up the new system pretty well with my Pro-96. I live not far from the monastery. It sounds like talkgroup 00001 is the Sheriff Dispatch and 00100 is Fire/EMS Dispatch. As mentioned before, there is also a talkgroup ID of 00010, but I am not sure what that is. Talkgroup ID 00006 appears to be the Sheriff Traffic channel. I get an occasional talkgroup ID of 00003 which sounds scrambled so that may be an encrypted talkgroup. As stated before, nothing seems to be coming across the old talkgroups. I am curious as to whether or not encryption will be enabled on the main dispatch channels once everything is up an running, if it isn't already.
There was a Rockdale News story about the swapover at
Final testing coming for emergency radio system
