Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Georgia Radio Discussion Forum
Georgia Radio Discussion Forum - Forum for discussing Radio Information in the State of Georgia.
  #21 (permalink)
Old 07-29-2013, 7:19 PM
Default Forsyth County
Is it just police that is on the system?
  #22 (permalink)
Old 07-29-2013, 8:40 PM
N8IAA's Avatar
SO, FD, and Cumming PD.
Larry
  #23 (permalink)
Old 07-29-2013, 9:02 PM
wise871's Avatar
From what I'm understanding we should add the Forsyth County 35XXX TG ID's to the Cobb System so if I'm just monitoring the Cobb P25, I will pick up those talk groups. I would add them like the Douglasville Police. Any thought? Otherwise the only way to pick them up is in search mode.
Dan
Uniden:BCD436HP,BCD536HP,BCD996p2,HP-1/2e,BCD396XT,BCD996T(XT),BCT15X, BC898T
Radio Shack:PRO-197,PRO-106
Vintage:PRO-25,Sony Air-8
  #24 (permalink)
Old 07-30-2013, 11:24 AM
N8IAA's Avatar
Living in Gwinnett, I can't help you on that one, Dan. Maybe B7spectra, or MetroFire31 can check that out.
Larry
  #25 (permalink)
Old 07-30-2013, 12:22 PM
Both North and South Dispatch tgs are coming through on Cobb as i'm typing this. I'm actually surprised these talkgroups aren't showing up on UASI...it's only going to be Cobb frequencies apparently. The million dollar tie-in grant that was used does seem to mostly benefit Forsyth at the expense of Cobb since us Cobb taxpayers would be on the hook for wear and tear, maintenance on the main P25 system. Cobb/Forsyth does not routinely do any mutual aid with each other since there is no shared border by a long shot.
  #26 (permalink)
Old 07-30-2013, 1:09 PM
MTS2000des's Avatar
Don't be so quick to condemn the powers that be at Cobb DPS. This is actually a good move, the first type of IGA of the kind in it's area. This is the first step in building bridges, bridges that have been a long time coming, in public safety radio.
The "wear and tear" is minor, the amount of time that FSY units will spend affiliated on Cobb sites will be minimal, and the administrative work is mostly on their end. The benefit is we now have a unified system that, in typical Cobb county fashion, "we lead, others follow".
When the Fulton DTRS becomes a reality, an IGA will most likely be signed with Fulton county, and that would benefit us GREATLY with needed fill-in coverage, especially on the south side of the county.
Hopefully the arrogant snobs in the "new" Milton county cities (except Johns Creek, who do see the light) will choose to join the new Fulton network and assimilate their resources.
and after all the hundreds of millions of dollars spent on disparate 800MHz trunking systems, we will FINALLY start to see some of that much promised end user interoperability and increased end user coverage the vendors have been hawking for the past two decades.
NO I will not help program your trunking radio. All opinions are exclusively those of the author and in no way reflect the position of his employer, contractors or other parties.
  #27 (permalink)
Old 07-30-2013, 6:14 PM
Larry
Not sure what is coming through on the Cobb system from Forsyth as I don't monitor it that much, but nothing from Cobb is currently showing up on the Forsyth system in ID search mode.
  #28 (permalink)
Old 08-07-2013, 10:48 AM
wise871's Avatar
I made some updates to the Cobb system today based on submissions and information provided. If the information is incorrect, please let me know.
Dan
  #29 (permalink)
Old 08-09-2013, 7:47 AM
The Jail on both the Cobb and Forsyth systems should only be 35221. I haven't heard anything on 35211. There used to be a Jail TAC that was rarely used so perhaps that is it, but I've been listening a few hours a day and haven't heard anything on 35211.
  #30 (permalink)
Old 08-09-2013, 2:03 PM
MTS2000des's Avatar
There seems to be quite a bit of confusion about what has taken place. These are two separate systems that share a single Smartzone master controller via a microwave hop.
The Forsyth talkgroups will be rarely heard on Cobb sites once the testing and massive reprogramming of subscriber radios on the Forsyth leg are complete, and you will rarely hear any Cobb TG's active on the Forsyth zone, as Cobb officers rarely move out of coverage of their home system into the coverage of Sawnee mountain.
The whole reason Forsyth talkgroups had to be changed was to prevent duplicates that were already in use on the Cobb zone. The UID's also had to be changed because of this, and to enable wide area roaming.
I think it is important (for scanner users) not to be confused when programming their scanners, and thus, the Forsyth and Cobb systems should be listed separately. They do after all, have different RFSS ID's, only the same WACN (as do most Astro 25 networks installed by Motorola in the Atlanta area, for future use of course).
For those unfamiliar, read up on how Smartzone OmniLink roaming works in an Astro 25 system, while this document was prepared for UCAN statewide DTRS in Utah, it's basic principles can be applied here:
http://siec.utah.gov/omnilink/docume...nkTraining.pdf
The key concept is DSA, Dynamic Site Assignment of talkgroups, which is what you experience as a scanner user when you start hearing Forsyth county talkgroups on "Cobb's" system and vice versa. This is the "roaming" between home zones function in action.
You will only hear Cobb talkgroups on FSY sites when the following conditions occur:
1)-a Cobb user who's radio is authorized for wide area roaming enters the coverage area of a Forsyth site, and either manually (from his/her radio) or automatically (if his/her radio is programmed) registers with the network on that roaming site.
2)-DSA will then occur, and the desired talkgroup that wide area user is using will be directed to the roaming zone, so if you are listening on a scanner in that zone, that talkgroup would then become active with that users "home" zone traffic.
3)-DSA will stay in place so long as: the roamer stays registered on the distant site, or if the system is placed into multi-zone simulcast by the system management. DSA will end when the roaming user de-registers, or after a set period of time by the system manager (usually 12-24 hours).
The same is true of Cobb talkgroups on the Forsyth sites. Only when a user requests, or system management institutes this, will you hear Cobb traffic.
This is to conserve RF channel resources on all zones (why bother sending it if no one is listening?)
I hope this clears up the confusion. You Forsyth folks should keep your Forsyth system in a separate bank, and only add the Cobb talkgroups if you're curious when a Cobb user roams onto your sub system and vice versa.
Again, these are two separate sub systems that share a zone controller that enables roaming between the two. In the future, it is possible that other systems become sub systems and join in. (Easier said than done...herding cats anyone?)
  #31 (permalink)
Old 08-09-2013, 3:39 PM
wise871's Avatar
Thanks for the info. The system has be reverted back to the original.
Dan
  #32 (permalink)
Old 08-09-2013, 8:44 PM
MTS2000des - Thank you for sharing your knowledge. Though most of it goes over my head, it's nice to see someone take the time to explain and share. I appreciate your expertise and professionalism here on the forum.
Thanks again.
BCD396XT, BCD325P2, BC95XLT, ICOM 880H, Yaesu FT-857D
  #33 (permalink)
Old 08-11-2013, 1:41 PM
MTS2000des's Avatar
Glad I could help.
  #34 (permalink)
Old 08-15-2013, 7:49 AM
TxDuster's Avatar
Got a quick question about the updated FC system. I heard several units go out on a foot pursuit this morning and they all switched to "Backup 2". I have my PSR 800 set up for open scanning i.e. wildcards, but heard nothing. I only have control channels in the rig right now. Does anyone know if Backup 2 is a TG or a simplex channel that would require having all the listed frequencies in the scanner?
  #35 (permalink)
Old 08-16-2013, 1:50 PM
Default I'm Lost
I have not had the 800 out in a while. I did updates because all was quite and all went well, not the first time doing them. I hear nothing from Forsyth county so I'm guessing I need to do the ID search mode. well I looking to hard and can't see it or just plan dumb. I've looked in the software and on scanner and can not find ID search mode, I do have a wildcard selected on the software.
I can hear Forsyth County online but nothing on my scanner.
Help
thanks in advance
  #36 (permalink)
Old 08-16-2013, 8:28 PM
N8IAA's Avatar
Help
thanks in advance
Add a Wildcard TG to the system. No ID Search for the 800. Do the update and get the new TGID's that are in the database now. There will be a couple of new ones very soon They are not using their old TGID's anymore.
Larry
  #37 (permalink)
Old 08-18-2013, 12:44 PM
Thanks for the help Larry, got it going. was driving me crazy trying to find the ID search and that's a short trip.
thanks again
  #38 (permalink)
Old 11-03-2015, 4:54 PM
DanRollman's Avatar
Just finding this thread, after trying to figure out why the Cobb and Forsyth systems in the database have identical Sys ID, Site ID, WACN and RFSS ID. I would not have been confused at all if Forsyth and Cobb had different RFSS IDs, as the above poster suggested. But in fact in the RR DB, they have identical RFSS IDs. That's the source of my confusion. Anyone know what the correct RFSS IDs should actually be in the RR DB?
Thanks,
Dan
  #39 (permalink)
Old 11-03-2015, 5:19 PM
nunyax's Avatar
Thanks,
Dan
Forsyth County is showing as RFSS 1, Site 005 thru Pro96Com.
Joe
Just one of the "little scanner people."
  #40 (permalink)
Old 11-03-2015, 5:20 PM
DanRollman's Avatar
Perfect! That solves the mystery. Thanks.
