Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Georgia Radio Discussion Forum
Georgia Radio Discussion Forum - Forum for discussing Radio Information in the State of Georgia.
  #21 (permalink)
Old 02-04-2014, 8:59 PM
nunyax's Avatar
Originally Posted by ButchGone View Post
After doing a little digging around in the FCC licenses for Georgia, it appears that for right now the only areas licensed to use P25 are in west central Georgia. Most are using 154.7025 as repeater output, with the Forsyth post on 154.920. All digi sites appear to use 155.4675 as the repeater input for the trooper cars. Interesting to note that the traditional Georgia hi band frequencies are also listed to operate P25 (154.680, 154.800, 154.905, 154.935, 155.370, 155.475) for these west central Georgia posts.
The rest of the GSP posts in the state have licenses recently renewed that only show analog emissions, like northwest Georgia. Hmmm...
BG..
The state has submitted an application for modification of license KIB607 to add a P25 repeater on 154.9425 for Thomson (McDuffie County) which is Post 25 out of Troop E. 158.985 looks to be the input.
ULS Application - Public Safety Pool, Conventional - 0006130461 - GEORGIA, STATE OF - Frequency Summary
Joe
Just one of the "little scanner people."
  #22 (permalink)
Old 02-08-2014, 9:20 PM
N8IAA's Avatar
Took a road trip to the Clayton, Fayette county area. GSP was heard on 154.7025/ NAC 625. Audio is definitely much better than their analog signals.
Just thought I'd let everyone know.
Larry
  #23 (permalink)
Old 02-09-2014, 1:23 PM
RRR RRR is offline
Does it make any difference to the audio quality, scan speed or other functionality of my scanner (996XT) if I leave no NAC code, or is it better to program the NAC code in, if I have it?
  #24 (permalink)
Old 02-09-2014, 3:12 PM
N8IAA's Avatar
The NAC is the P-25 version of CTCSS/DCS. It makes the scanner listen for the tone. I was using my 396XT. Audio has nothing to do with NAC. Programming the NAC is up to you. I do it to verify that the tone is correct. When I'm searching, I leave it in search mode and write down the code.
Larry
  #25 (permalink)
Old 02-10-2014, 10:31 PM
nunyax's Avatar
Default Troop "E" may be the next to go digital
On Friday 2/7 at 19:00, GSP Troop "E" broadcast to it's posts to switch over to sheriff's band and they're still on it. Tonight I heard a trooper ask the Monroe Post 46 dispatcher how long they would be using it and he was told "about a month and then we'll have a new system."
Joe
  #26 (permalink)
Old 02-11-2014, 12:21 PM
N8IAA's Avatar
Wonder how long before other troops will change over to P-25.
Larry
  #27 (permalink)
Old 02-11-2014, 1:02 PM
RRR RRR is offline
Does anyone have an easy to use guide as to which posts and troops are using what freq. now? (and if still analog or digital, etc.) All I have is a little here and there.
  #28 (permalink)
Old 02-11-2014, 6:28 PM
nunyax's Avatar
Default More GSP Troop E P25 repeaters
Here's another Troop E GSP license with a pending application to add a P25 repeater:
ULS Application - Public Safety Pool, Conventional - 0006132923 - GEORGIA, STATE OF - Frequency Summary
Post 33 in Milledgeville is adding 155.4525 to license KIF866.
And another, in my own backyard:
ULS Application - Public Safety Pool, Conventional - 0006132383 - GEORGIA, STATE OF - Frequency Summary
Post 46 in Monroe is adding 154.9125 to license WXP675.
Joe
  #29 (permalink)
Old 02-11-2014, 10:44 PM
RRR RRR is offline
Are all of these new GSP channels digital?
  #30 (permalink)
Old 02-11-2014, 11:40 PM
N8IAA's Avatar
Indeed they are. P-25 according to the designator.
Larry
  #31 (permalink)
Old 02-12-2014, 10:49 AM
RRR RRR is offline
Thank you! I didn't know if they used both analog and digital, so I will set my 996xt to "Digital" on these freqs.
This will be interesting, is the frequency designation by Troop, by post or what? Glad to see something new, but will miss the standard 2 channel pair used almost statewide
  #32 (permalink)
Old 02-12-2014, 11:19 AM
N8IAA's Avatar
No, set it to ALL. Set the MOD to AUTO. This way if they are still using analog, you will be able to hear them.
Larry
  #33 (permalink)
Old 02-12-2014, 11:23 AM
N8IAA's Avatar
Just expanding their frequencies, they will still be using 154.68/154.8.
Larry
  #34 (permalink)
Old 02-12-2014, 11:27 AM
RRR RRR is offline
Doesn't it affect something (Scan rate or decoding rate or something) if I set it to "auto" v/s digital? I thought I read somewhere it did.
  #35 (permalink)
Old 02-18-2014, 9:18 PM
Default More new GSP P25 freqs
Snooping around in the FCC files, I found these frequencies now licensed to KA5323, callsign for GSP mobiles. They seem to align with some of the earlier posters hearing P25 repeaters on the air. The freqs with an asterisk * are showing analog only mode, which makes sense since they're interops freqs long in use. All others are licensed for P25. I would imagine some of these are mobile inputs to future repeaters:
154.6650
154.6725
154.6800
154.6875
154.7025
154.7925
154.8000
154.8075
154.8900
154.8975
154.9050 *
154.9125
154.9200
154.9275
154.9350 *
154.9425
155.4600
155.4675
155.4750 *
155.5125
158.9850
159.0450
Guess we should listening for these to become active.
BG..
ButchGone
  #36 (permalink)
Old 02-20-2014, 7:13 PM
There is a trial going on in Troop D with 3 repeaters one at Newnan,Forsyth,and Manchester.There are others coming but I can't remember. Maybe one of them was Grovetown next.
  #37 (permalink)
Old 02-21-2014, 12:15 PM
Default GSP going digi?
In the Grovetown area I am hearing the 154.7025 frequency as digital noise much like TRBO/NXDN. I am using a PSR-800 which decodes P25. Also, they are dispatching off Sheriff Net.
  #38 (permalink)
Old 02-21-2014, 4:54 PM
RRR RRR is offline
I heard the same digi noise in Bibb county yesterday. I was hoping they would all be P25 unencrypted
  #39 (permalink)
Old 02-26-2014, 6:24 PM
Talked to a radio tech today at GEMA, asked him about GSP encryption and was told nothing would be encrypted as far as he knew.
  #40 (permalink)
Old 03-01-2014, 4:21 AM
Anybody know if any p25 traffic at gsp post 42 northwest ga
