Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Georgia Radio Discussion Forum
Georgia Radio Discussion Forum - Forum for discussing Radio Information in the State of Georgia.
  #21 (permalink)
Old 06-28-2014, 9:53 AM
tonydugan's Avatar
I suggest the freqs associated with WNVR832.
  #22 (permalink)
Old 06-28-2014, 10:43 AM
mjbjr's Avatar
huh
Macon-Bibb County Sheriff Office (Georgia)
Running off a Pro-197
  #23 (permalink)
Old 06-28-2014, 10:52 AM
MikeOxlong's Avatar
Originally Posted by RRR View Post
Would unchecking "Control channel only" help?
No. "Control Channel Only" only helps if he has all the control channels programmed in.
If he's missing a control channel than it won't help find it.
He needs to make sure he has all the frequencies for the site programmed in and if he's still not following the system on certain days, he needs to find the missing control channel.
Mike.
  #24 (permalink)
Old 06-28-2014, 11:24 AM
troymail's Avatar
He's recommending that the frequencies assigned to this FCC license (WNVR832) be applied to the system in your radio(s) and see if that helps.
855.2125 (existing on the RR database listing)
855.5875
855.8875
855.9875
856.9875
Since this is what is listed on the license and the only common one between the license and the RR listing is 855.2125, you may only be hearing the system when it uses 855.2125 as the control. However, when the CC switches to a different control channel frequency that isn't listed on RR (and may be one of the above), your radio will go silent.
Having said that - there are two systems in the area - which one are you trying to listen to?
Central Georgia Interoperable Regional Radio System
Central Georgia Interoperable Regional Radio System Trunking System, Various, Georgia - Scanner Frequencies
(assuming the FCC callsign listed for this system on RR is correct - WPXX405 - RR is only listing 7 frequencies but the license shows 12).
or
Macon-Bibb City Services
Macon-Bibb City Services (P25) Trunking System, Macon-Bibb, Georgia - Scanner Frequencies
(assuming the FCC callsign tont reports is correct - WNVR832 - and it probably is since there is RR shows one of the frequencies for that license for this system, then it is likely - based on the FCC license that the RR listing is not showing the correct frequencies).
You can try entering the correct/additional frequencies listed under the respective licenses and see f that helps.
The best way to know for sure what the system frequencies are as well as find the correct FCC callsign is probably to use Pro96Com (Pro96Com - Control channel decoder for P25 Trunked Radio Systems).
Unication G5(UHF)
  #25 (permalink)
Old 06-28-2014, 11:44 AM
tonydugan's Avatar
855.2125
855.5875
855.9875
856.9875
855.8875
These are working for Bibb So and Fire as well as Toby rangers. Not sure of the descrep with RR, unless they've rearranged the freqs.
  #26 (permalink)
Old 06-28-2014, 7:48 PM
RRR RRR is offline
What if you have a couple of channels in the mix that aren't control channels? Will this degrade performance or otherwise hinder you when listening to the site(s)?
  #27 (permalink)
Old 06-28-2014, 8:38 PM
I was able to run pro96com for a bit this evening on the Central Georgia Interoperable Regional Radio System and these are the frequencies shown.
854.06250 a
854.71250 a
855.23750 a
855.48750 a
855.58750 c
855.88750 a,v
855.98750 a,v
856.23750 a,v
856.26250 a,v
856.58750 a,v
856.98750 a,v
857.48750 a,v
Mark.
  #28 (permalink)
Old 06-28-2014, 9:12 PM
MikeOxlong's Avatar
Perfect. I've added those in.
Any chance you can run Pro96Com on the Macon-Bibb City Services system?
Currently there's 5 channels listed and I'd like to verify them.
Thanks.
Mike.
  #29 (permalink)
Old 06-28-2014, 9:16 PM
MikeOxlong's Avatar
Default Macon/bibb
Nope, no problem at all. In fact, with a Harris system (and possibly others), any channel can be used as a control channel so it's best to include them all.
What we really needed was for somebody to run Pro96Com or Unitrunker on the system or at least do a basic search to see if the control channel had moved.
Now that somebody has shown some initiative and provided us with an actual list of frequencies used by the system, things should be better for everybody.
Mike.
  #30 (permalink)
Old 06-28-2014, 10:09 PM
Thanks.
Mike,
Pro96Com shows all but the 857.23750.
FWIW, there were no radio affiliations or traffic during the time I was able to monitor this system.
Nice band opening after a thunderstorm, hopefully it helps others get back in the game.
Mark.
  #31 (permalink)
Old 06-30-2014, 3:55 PM
I'll update the FD feed radio w/ the new channel information. Thanks for the updated info f4jmk.
  #32 (permalink)
Old 06-30-2014, 4:20 PM
troymail's Avatar
Great teaming!
Go Team!
Unication G5(UHF)
  #33 (permalink)
Old 07-07-2014, 4:13 PM
mjbjr's Avatar
854.06250 a
854.71250 a
855.23750 a
855.48750 a
855.58750 c
855.88750 a,v
855.98750 a,v
856.23750 a,v
856.26250 a,v
856.58750 a,v
856.98750 a,v
857.48750 a,v
Mark.
Thank you for doing this. I appreciate it.
  #34 (permalink)
Old 07-14-2014, 1:55 PM
AE4VE's Avatar
Isn't Macon - Bibb pprimarily on p25 phase II now?
  #35 (permalink)
Old 07-16-2014, 12:02 AM
N8IAA's Avatar
I suggest that you go to the beginning of this thread and read the posts.
But since you are a new member, the system is Phase II, but does not use TDMA talk group ID's.
Larry
  #36 (permalink)
Old 07-17-2014, 12:43 PM
AE4VE's Avatar
Larry
Actually, I did read every post on this entire thread. But you were right about me being new to this forum. I'm also fairly new to scanning and programming entirely.
Not one of the previous posts in this thread mention anything about p25 phase II.
I was just asking a simple question. But thanks though.
