MasonRobersonMD
- Joined
- Jun 23, 2016
- Messages
- 25
I just bought a BaoFeng UV-5R Dual Band Two Way Radio. I know i'v seen a ton about licensing, but I went to the FCC website, and according to them to use the Multi-Use Radio Service (MURS) you do not need a license. Therefor can I use my BaoFeng UV-5R without one? and use the MURS Freq. From the FCC -""MURS is licensed by rule. This means an individual license is not required for an entity to operate a MURS transmitter if it is not a representative of a foreign government and if it uses the transmitter only in accordance with Section 95.1309. There is no age restriction regarding who may operate an MURS transmitter."" So what im taking from that is as long as I use any of the following freq. I'm good to go as long as I follow "licensed by rule"...
151.820 MHz (11.25 kHz)
151.880 MHz (11.25 kHz)
151.940 MHz (11.25 kHz)
154.570 MHz (20.00 kHz)
154.600 MHz (20.00 kHz)
