Go Back   The RadioReference.com Forums > Topic Specific Forums > GMRS / FRS
GMRS / FRS Discussions related to GMRS (General Mobile Radio Service) and FRS (Family Radio Service)
Old 02-17-2012, 8:32 AM
Default can any of the Wouxun Radios work on MURS?
Just wondering if any Wouxun's will work on MURS?
thanks
Old 02-17-2012, 8:58 AM
Check transmit frequency range the specifications.
If the radio transmits 136-174 MHz it will work on MURS.
Some Wouxun models only transmit on the 2 meter amateur band 144-148 MHz.
None of the Wouxun radios are certified for Part 95 so legally you cannot use them on MURS or GMRS.
Tom
Old 02-17-2012, 9:12 AM
thanks, yeah I know they are not part 95 legal, just wondering, in a SHTF scenario if my wouxun kg-uv3d could do it.
Specs say tx. 144-148 rx 136-174
thanks
Old 02-17-2012, 9:24 AM
MURS frequencies are in the 151-154 range.
It will not transmit on MURS unless you have the software to unlock it, but if you are using it on GMRS you probably already did that.
Tom
Old 02-17-2012, 9:33 AM
gmrs is not legal either on these radios that I knew, just wondering incase of a SHTF type thing...
In a hypothetical SHTF type thing I wonder how far a radio with 5 watts would be able to talk to another 5 watt radio on the MURS freq.
Old 02-17-2012, 10:16 AM
There is no good anwser to that because there are too many variables that affect radio range. It depends on your surroundings, terrain, type of antennas used, operator skill and other things. Using VHF or UHF hand held radios with typical stock antennas and .5 to 5 watts your range should be anywhere from several hundred feet to 20 miles or more.
Tom
Old 02-17-2012, 10:35 AM
Hypothetically wouldn't the murs be able to go farther outdoors with 5 watts then the gmrs, because of the VHF doing better against trees and hills...etc (thats what I have read about vhf) then the uhf gmrs on 5 watts?
Old 02-17-2012, 11:14 AM
People continually ask about HT radio range. The post above by ND5Y summarizes the best answer to the question and should probably be made a sticky on the Board. THERE IS NO HARD AND FAST ANSWER TO THE QUESTION. There are too many variables involved.
Old 02-17-2012, 11:16 AM
I understand.
Just chatting about something (two-ways) we are all interested in is all...
Old 02-17-2012, 11:57 AM
It depends on your surroundings. Sometimes UHF might be better. Sometimes VHF might be better. Using hand helds there is generally not that much difference between 150 and 450 MHz.
Tom
Old 02-17-2012, 6:06 PM
this model-KG-UVD1P does comply with fcc regs 47cfr part 2 (j) / ansi and ieee c95.1-1992 / icnirp 1998 exposure guide lines...and complies with fcc part 90 with directives 1995/5/ec compliances...it will do the murs freqs...ii have this dual band model and love it
Old 02-17-2012, 8:26 PM
In my personal experience between 2 dual band HT's on simplex, at 2 miles apart, switching between VHF, & UHF, VHF worked better. Both radios never moved while switching between VHF, & UHF. One radio was at a 3rd story window, & one was at ground level. GARY N4KVE
GARY N4KVE
Old 02-18-2012, 12:22 AM
thanks
as others have mentioned it is illegal, But for a SHTF scenario it will work. I have the MURS, GMRS and FRS frequencies programmed in my Wouxun. Other than testing to make sure it works, I do not use this radio on those frequencies. I just like to have the capability in case of emergencies.
Old 02-18-2012, 2:30 AM
RadioDitch's Avatar
The Wouxun dual-band portables are Part 90 approved however fwiw. A very convenient fact for hams who are also emergency responders...
73, W2MJR/EI7D
EMT/Railfan/Certified Nerd
Union County, NJ - Morgan County, WV - Baldoyle, IE
Confucius Say: "Communications techs do it on-air."
Old 02-18-2012, 2:38 AM
Originally Posted by W2MJR View Post
The Wouxun amateur radio dual-band portables are Part 90 approved however fwiw.
GMRS/FRS and MURS are part 95
Old 02-18-2012, 8:02 AM
So am I reading this right that the KG-UVD1P can be used?
Old 02-18-2012, 9:05 AM
You don't seem to understand.
The KG-UVD1P, KG-UV2D, KG-UV3D and KG-UV6D each have various versions with different band splits.
Some of them only transmit in the amateur bands and need to be unlocked.
Some of them will not cover certain frequencies at all.
Tom
Old 02-18-2012, 10:16 AM
Oh I understand, I own a KG-UVD1P and a KG-UV3D
I was asking if the KG-UVD1P was fcc compliant for murs?
Someone stated an FCC rule above.
Old 02-18-2012, 10:21 AM
jhooten's Avatar
No, the radios are only Part 90 approved. MURS and GMRS are Part 95.
Jerry
I read it on the internet, so it must be true.
Old 02-18-2012, 3:46 PM
Simple answer. they can tx/rx on murs and gmrs if you unlock them, pretty easy. Is it ok? The fcc says no. Do it at your own risk.
