Is there an emergency channel on MURS?
kc0bus
Greetings,
I was just wondering if anyone might happen to know if there is any kind of agreed-upon official or semi-official emergency channel in the MURS service, and if so, what is it?
Thank you
teufler
ST PETERS, MISSOURI
Only 5 channels, easy to scan. Most MURS used as business frequencies so if they would have an emergency, I think they would be talking on whatever frequency that had been operating on.
Most mobile to base, so a contact would always be there, I would think. Not like cb with channel 9 or FRS, don't think FRS has one. Most FRS is such sort range you could wave at each other for an emergency. I guess maritime has a emergency channel, I think its channel 16.
WQWG712
Garland Texas
Channel 20 is the emergency Channel!
which is Frequency 162.675 PL tone 141.3
If you are on a Family FRS radio its Channel 20 and PL 20,
But since FRS transmits at 1/2 watt it may not work if you are to far from Repeater!
ecps92
Taxachusetts
Correction 462.6750 is a GMRS Freq, not an FRS
and Simplex won't trip a Repeater
which is Frequency 462.675 PL tone 141.3
wtp
Port Charlotte FL
the word is no.
gmrs ch 20 is an un-official travelers assist/emergency channel and is 462.675/467.675 141.3pl
frs ch 1 is an un-official calling channel and has no repeater function.
and i have not seen in quite some time a sign for cb ch 9 being monitored.
ron36
chesapeake va
C.b. Channel 9 is the official Emergency 27.065 MHz Official FCC Travelers assistance channel !! May or may not be monitored Regularly depends on location !! Cell phones as we know took over!!! Again depending on location ! 462.6750 GMRS is unofficial channel !!! some locations use 18 some 20!!! Murs Does Not Have An Emergency Channel !!! Maritime : Emergency channel 16 Marine Band 156.800mhz General calling for boaters Channel 9 156.4500mhz. Marine Band !!!! FRS/Gmrs radios Are considered Alternative communications and not truly considered A primary active set of Bands !! Depending on locations !! not every city has a React Team !! I would listen FRS 1 official calling channel in a Disaster event !!!! FRS/GMRS 1 462.5625 is official calling channel !!! Honest Answer !!! and down below. some one has. 162 .675 MHz !! you better not transmit on it. As its a Weather NOAA channel !
ron36
chesapeake va
C.b. Channel 9 is the official Emergency 27.065 MHz Official FCC Travelers assistance channel !! May or may not be monitored Regularly depends on location !! Cell phones as we know took over!!! Again depending on location ! 462.6750 GMRS is unofficial channel !!! some locations use 18 some 20!!! Murs Does Not Have An Emergency Channel !!! Maritime : Emergency channel 16 Marine Band 156.800mhz General calling for boaters Channel 9 156.4500mhz. Marine Band !!!! FRS/Gmrs radios Are considered Alternative communications and not truly considered A primary active set of Bands !! Depending on locations !! not every city has a React Team !! I would listen FRS 1 official calling channel in a Disaster event !!!! FRS/GMRS 1 462.5625 is official calling channel !!! Honest Answer !!! and down below. some one has. 162 .675 MHz !! you better not transmit on it..!!!! Its not a FRS /Channel !!!
