Originally Posted by BOBRR
Is there a "summary list" posted somewhere for the greater Boston area that shows what's been "re-banded," or do you have to dig each freq. out individually and check from the RR listings ?
You can go to
the 800 MHz Transition Administrator's page and enter the system's call sign (not the frequencies; the call sign) in the box. When you click
Go, another page will pop up (you must override any pop-up suppression by pressing the
Ctrl key at the same time you click on
Go) showing the frequencies licensed to that call sign and what the frequencies will be after rebanding. If rebanding is finished, it will indicate that no further changes will be needed.
Rebanded systems will not have any 800 MHz frequency over 861.0000 MHz if I recall correctly.
Actually, you should probably ask this question in the
Massachusetts Discussion Forum because the active local members should know what is or is not rebanded.
