Old 03-23-2008, 12:51 PM
Default PSR-500 scan list scanning
I arranged one scan list with conventionals and NAC codes- scan list 4.
Scan list 5 is a grouping of limit searches.
Scan list 6 is trunked objects.
In global the default scan list is set to 6.
In global scan list 4, 5, and 6 are selected.
While scanning lists 4,5,6 the radio is making me think it's not hitting everything.
I toggle scan list 5 and 6 off to scan only scan list 4. When i hit manual, you would think i would only see the conventional NAC's i stored in scan list 4, but i see stuff from scan list 6.
***I notice if i hit the back or forward arrow it will bring me back to the objects in scan list 4. I then hit scan, then manual, and the objects in scan list 4 stay there.
Now if i toggle 5 back on, or 6, as im still scanning objects in 4, am i still hitting it all?
Another thing i notice while in scan list 4, i can turn the squelch all the way down, hit scan with 5 on with the limit searches, and i will only see channel as it's moving at the bottom of the display. Once i turn the squelch up to a certain point, then the display alternates between "channel" and "limit search". I take it with squelch turned all the way down it is only scanning scan list 4 and not moving through 5.
What is bothersome is if i toggle 5 and 6 off with 4 on, i want to see what is in 4 right away. Or if i only want to see what is in 5- and shut 6 and 4 off. Anyone know what im talking about here?
Thanks.
Old 03-23-2008, 01:13 PM
KB1KBD's Avatar
Press PSE (pause) instead of manual. Manual will display what was active the last time you used manual not what is currently being scanned. PSE only works while scan is holding on an active channel. The only way I know of to stop the scan on the active scan list is to crank the squelch CCW then hit PSE and return the squelch to where is was.
73, de KB1KBD
GRE PSR500
Uniden BC785D
Uniden BC55XLT
Icom 2100H
Yaesu VX-7R
www.seacoastscanning.com
Old 03-23-2008, 01:20 PM
Thanks. All i can say is this radio has it's own brain! Imagine the thing further, more reception of systems we cant hear yet, user voice activation/command hands free....
I guess we can count the stuff we have as better anyway, im pleased with what the radio will do all in one spot.
C.
Similar Threads
gre psr 500 in Ocean County Highpockets New Jersey Radio Discussion Forum 3 11-27-2007 05:38 PM
PSR 500 Programming Question rsklar GRE Scanners 8 11-18-2007 07:36 PM
Ht1250 scan list 7586 Motorola Forum 2 07-03-2007 12:53 AM
MT-1000 VHF Scan List Questions mattgregg110 All Other Receivers 7 04-26-2007 08:28 PM
Scan CB band with scanner or buy a CB with scanning ability? mh34444 General Scanning Forum 7 07-23-2005 01:40 AM
