Reception Problems GRE 500
I have a GRE PSR 500 and have noticed when I have it locked on a control channel or and active channel and I wiggle on the antenna I get mixed results, it will distort and maybe go from a 99% to 15% like it is losing contact. This is with a external antenna, am wondering if anyone else has had this problem. The connector seems to be tight everything else looks fine. I have checked the "Known screw inside scanner to be loose" was loose but had no affect on this problem. Thanks for any information you can give me.
PSR 500 , Pro 2096
