Old 05-08-2008, 01:35 PM
Stavro35's Avatar
Send a message via AIM to Stavro35 Send a message via MSN to Stavro35 Send a message via Yahoo to Stavro35
Unhappy PSR 500 all but deaf.
My radio isn't working correctly,of that I am certain. I am sitting here with my Pro97 and PSR 500 now. The PSR 500 is all but completely silent compared to my Pro97.. I've paused the PSR 500 on the Seattle/King county TRS and it's working fine at the moment. I've also put it on Boeings TRS and it works fine. The second I put it into scan,it will randomly "hear" again.
The conventional frequencies are working fine.However , I am not hearing any aviation, no coast guard. I am hearing conventional traffic .. WSP .. I am currently "parked" on the Boeing TRS .. Some talkgroups are coming in just fine. Others are coming in so weak I have to put my ear up to the scanner to make out what they're saying.
Would it be just a matter of reloading my current data file?
HELP!
http://www.scanseattle.net
My scanner feed and more!
Radio shack Pro96
Radio shack Pro164
GRE/PSR 500
Radio shack Pro2006
Radio shack Pro 2052
Icom IC R-75.. Long wire antenna.
Old 05-08-2008, 03:34 PM
bneilson's Avatar
This same type of issue has been mentioned before and usually traces back to the Multi-Site function. Check to see if you are maybe set to ROAM or STAT as they could impact your ability to receive. Assuming this is a multi-site system you are listening to.
Old 09-28-2008, 11:07 AM
64larry's Avatar
I have the same problem with my PSR-500. Check and see if your squelch settings (located in the expert settings menu) has been changed. If so you may need to reset them back to default. But with the same problem happening with my scanner and the LA police Dept. vs the Pro-96. My Pro-96 picks up and is more sensative on trunking than the PSR-500. You probably need to check the GRE site to see if their are firmware upgrades.
-- Larry N7LWB
Old 04-06-2009, 10:41 PM
CBFD's Avatar
my pro-97 is/was a way better radio than my psr-300 that's for sure... my pro-97 would pick up th HRM Fire Repeaters in Halifax... and this thing... well I might as well not have it at all... very disapointed in this gre scanner.
Old 04-06-2009, 11:16 PM
Stavro35's Avatar
This is an old thread. My radio,the original one,was defective. I've yet to have any problems with my replacement
Radio shack Pro96
Radio shack Pro164
GRE/PSR 500
Radio shack Pro2006
Similar Threads
Portable Digital Scanner Purchase - GRE PSR 500 vs RS Pro 96 vs Uniden BCD396 robo21 General Scanning Forum 9 09-29-2008 06:25 PM
PSR 500 Scanlist Order m4a3t GRE Scanners 33 05-14-2008 12:26 AM
PSR 500 scanning/receiving strangely rawman GRE Scanners 9 03-19-2008 10:24 PM
Radio shack Pro97 to PSR 500? Stavro35 GRE Scanners 3 01-05-2008 01:12 PM
Question on PSR 500 Multi Roam Programing scannerfan3155 GRE Scanners 7 12-25-2007 09:21 AM
