1. Connect the headphone output of the PSR-500 to an audio input on your PC
2. In Win500's "Configuration" menu, select the audio input device used in step (1)
3. In Win500, check the "Record" options for the object(s) you want to record (TGRP or CONV objects)
4. In Win500's "Monitor / Control" tab, check the "Record" box.
While "monitoring", Win500 will then create WAV files for each transmission.
I'll keep my freedom, my guns, and my money... you can keep the change
