Old 10-21-2008, 11:02 PM
Chevyman22360's Avatar
Default Gre PSR 500 Desense
I have a GRE PSR 500 and use it mostly for mobile, which I have a NMO mount Larsen 150/450/800 antenna. What my problem is, the 450 Mhz is weak, where there is repeaters just a few miles away they are really static. I am wondering what I need to fix this problem. The antenna mount and connector is really good shape. I have really good reception on the 150-160 Mhz. Any ideas would be great. Thanks in advance.
PSR 500 , Pro 2096
Old 10-21-2008, 11:14 PM
K2QI's Avatar
You and I have opposite problems. I get poor air band reception in my area, whereas 400mhz and up is strong.
In my case, I get what I assume is desense or overload of the air band frequencies; sometimes I get 5 bars but nothing but static on certain frequencies. It doesn't seem to help swapping antennas.
Old 10-21-2008, 11:15 PM
jambo's Avatar
What type of mount ?
Magnet mount, etc. ?
What system are you trying to receive?
Need these in order for people to help ya out..
Old 10-21-2008, 11:32 PM
I have a NMO through hole mount, and basically just conventional frequencies.
PSR 500 , Pro 2096
Old 10-23-2008, 07:50 AM
Anyone have any more ideas???
PSR 500 , Pro 2096
Old 10-23-2008, 08:39 AM
detroit780's Avatar
Default 450 MHz reception
Have you checked the SWR at the frequencies you have issues with? Maybe the antenna has a bad coil for 450MHz? Is there water in the NMO connector? Is there a short in the coax? Is the coax good?
Les
Les W8MSP
http://W8MSP.com
http://Michigan-Radio.com
E-Mail W8MSP@W8MSP.com
Old 10-23-2008, 10:59 AM
Les
I have not checked the SWR, not sure how to do that. Could be a bad coil, I do have another identical antenna I will swap and see if it improves. The coax is good, was a brand new installation a month ago.
Thanks for the ideas.
PSR 500 , Pro 2096
Old 10-23-2008, 11:11 AM
Highpockets's Avatar
If it rained, you still could have got water in the connector, just a thought!
Steve
BC780xlt ~ BC785D ~ BCD996XT ~ PSR600
Old 10-23-2008, 11:14 AM
Are you talking about water where the antenna screws onto the NMO? That is dry, unless water in the coil? Not sure on that.
PSR 500 , Pro 2096
Old 10-23-2008, 11:16 AM
Yes, I have seen water in that area where is screws on, it was only a thought.
Steve
Old 10-23-2008, 11:59 AM
Tom_G's Avatar
Wink
A couple things to think about...
Handheld radios are designed to be "HOT" receivers with a rubber duck antenna.
When you attach an external antenna with gain to a handheld radio it can overload easily.
The GRE/Radio Shack radios are especially sensitive the the VHF range.
I recommend trying the attenuator on those nearby UHF frequencies and see if that helps.
When a scanner gets overloaded it can either make the signal sound scratchy and distorted or actually sound weak. Kinda strange, but that is what I have seen.
When I turn the attenuator on, it takes the distortion right away and it then sounds clear as a bell. Thank God for channel specific attuation.
Let us know if that helps.....
Tom/G, N1VVD
Scanners - RS PRO-97, 2055, GRE PSR-500, PSR-600
HF Radio - Icom 746
D-Star Radios - Icom ID-800, IC-91AD, IC-2820
Old 10-23-2008, 07:20 PM
I have tried the attenuator as the signal was active and then heard nothing after I pressed the attenuator button. It is hard for me to understand, the other day I was driving down the road and passed a truck that I had the frequency for and seen him talking on his radio and the signal was very week. His repeater was only 3-4 miles away. I know it is not my radio, I have a pro 96 that I use and same reception quality.
PSR 500 , Pro 2096
Similar Threads
Portable Digital Scanner Purchase - GRE PSR 500 vs RS Pro 96 vs Uniden BCD396 robo21 General Scanning Forum 9 09-29-2008 06:25 PM
GRE PSR 500 users question jjrii Delaware Radio Discussion Forum 2 07-28-2008 07:04 AM
FS/ Trade GRE PSR 500 pmlock1 Old Classifieds Archives 10 06-17-2008 09:27 AM
My Pro 97 and GRE PSR 500 Shack Install btritch Pictures Of Your Shack/Mobile Setup 17 05-28-2008 01:21 AM
gre psr 500 in Ocean County Highpockets New Jersey Radio Discussion Forum 3 11-27-2007 05:38 PM
