Old 11-14-2008, 05:34 PM
Default ID Tracker II - Version 2.0.3 Released
* Adding Radio IDs in audio segment index will immediately update tags for all occurrences in index.
* Corrected issue where Radio IDs were not being reset between transmissions.
* Corrected issue that caused Radio IDs of "0" to be created.
ID Tracker Mirror: http://209.240.24.87/idtmirror/IDTracker.htm
David M. Hitchner - K5DMH
Baton Rouge, LA
Baton Rouge Area Scanning: http://bellsouthpwp.net/k/d/kd5eis
ID Tracker/ID Tracker II: http://bellsouthpwp.net/k/d/kd5eis/i.../IDTracker.htm
Similar Threads
ID Tracker II keithmj Scanner Programming Software 2 09-07-2008 09:11 PM
ID Tracker II - Version 1.16.1 - Released brscanning Scanner Programming Software 4 10-06-2007 03:15 PM
ID Tracker II - Version 1.16.0 - Released brscanning Scanner Programming Software 1 08-22-2007 09:02 PM
ID Tracker II - Version 1.14.2 brscanning Scanner Programming Software 0 05-27-2007 06:00 PM
ID Tracker, update released! MacombMonitor Scanner Programming Software 19 02-06-2006 06:52 PM
