Old 11-20-2008, 01:15 AM
Send a message via ICQ to ShawnCowden Send a message via Yahoo to ShawnCowden
Default problems psr 500
I cant get my usb cord to work at all with my scanner and I need help with it it might be something about port settings but I did a port scan and it said no scanner found HELP!!!
Shawn Cowden, KG4KBU
London, KY
HOMEPAGE: http://www.myspace.com/KG4KBU
AIR AMERICA RADIO: http://www.airamericaradio.com
FREECYCLE: http://www.freecycle.org check it out its a neat site!!!
Old 11-20-2008, 01:20 AM
Windows Vista Btw
London, KY
Old 11-20-2008, 01:59 AM
tobarger's Avatar
Default Help
The COM port number assigned to the USB cable by your computer. If you are running a Windows operating system, you can find this information under “Ports” in the Device Manager.
Old 11-20-2008, 02:17 AM
yes I know and my port is 41 and psredit will not take that port only up to 32
London, KY
Old 11-20-2008, 03:05 AM
eyes00only's Avatar
I had a hard time too, but I did Win500. The solution was in the software program under configuation, I think.
If I remember correctly, I had to check several port settings before I found one that worked.
JK
"There is a fine line between 'hobby' and 'mental illness'."
Old 11-20-2008, 05:49 AM
mandlair's Avatar
Send a message via Yahoo to mandlair
And I think you can change the port number in ports in device manager.Mike
RADIO SHACK PRO-96/RADIO SHACK PRO-2036/RADIO SHACK PRO-197/GRE PSR500/UNIDEN 200XLT/YAESU VX-7R/KENWOOD TM-V7. callsign KB3LZZ
Old 11-20-2008, 07:36 AM
mikey60's Avatar
Edit the PSREdit500.ini file and change the port there. It's in the [Communications] section. I'll add more port values to that drop down for the next release.
http://www.psredit.com
Old 11-21-2008, 10:49 PM
how do i do that mikey
London, KY
Old 11-22-2008, 08:39 AM
mikey60's Avatar
Open the folder where the PSREdit500 program is located. In that folder you should find a PSREdit500.INI file. Double click on it and open it with notepad or any other text editor.
Within that file you'll find a line that looks like this:
[Communications]
That's the start of the Communications section. Just under that line you should see a line similar to this:
Port=32
Change the number in that line to 41 from whatever it is now, and then save the file. As long as you don't go into the serial port editor in PSREdit500, it should work for you.
Old 11-22-2008, 01:23 PM
mikey60's Avatar
I just uploaded an update to PSREdit500 that will allow you to go up to COM64 from the GUI...
Old 11-22-2008, 01:44 PM
Suggestion... why not allow anything that Device Manager will allow (COM1 - COM256)? It's not as if you have to actually populate the control's "data" at edit/compile time - you can just add the strings to the control in your WM_INITDIALOG handler (presuming it's a combo / drop-down list box in a dialog box).
The "slick" way, of course, would be to try to open COM1 through COM256, and only add strings for those ports where CreateFile() doesn't result in ERROR_FILE_NOT_FOUND. (ERROR_ACCESS_DENIED could be used to flag ports that exist but are already opened).
EDIT: Heh... like this if you're using any of my WinXX programs.
Old 11-24-2008, 05:34 PM
mikey60's Avatar
It will support it currently if you edit the ini file... Going all the way to 256 would actually not be too hard to do, and I may do that as soon as things settle down a little around here.
MIke
Similar Threads
Question about the PSR 500. AlphaDelta10 GRE Scanners 4 07-20-2008 04:55 PM
Ho Do You Record On The PSR 500 Using Win 500 Software... btritch GRE Scanners 3 06-25-2008 09:23 PM
Programming Files Into PSR 500 btritch GRE Scanners 12 05-21-2008 06:49 PM
PSR 500 Logging Chevyman22360 GRE Scanners 17 05-07-2008 05:39 PM
Radio shack Pro97 to PSR 500? Stavro35 GRE Scanners 3 01-05-2008 12:12 PM
