Originally Posted by cbro298
C an you program with only talkgroup id's? I have come across some info but it only provides the talkgroup ids and i am having trouble with the programming.I went to the manual but it is a little confusing.Any suggestions will be welcomed.BTW i have the computer download installed this is going to be manual
If I understand you correctly NO you will need site freqs and tg numbers.
Have you looked at
Scanner Frequencies: Palmetto 800 Trunking System, Various, Multi-State
I dont use the arc software anymore but based on arc396, with ARC software you should be able to do a internet import from Radio Ref database.
After doing this just click on tg's in the left part of screen and you will get a form where you can change the alpha tags.
Entering them manually through the radio is not easy but can be done.
also take a look at psredit500 or win500
both have a 30 day free use and I think you will dump the ARC and buy one of these.
Both so much easier to use.
Hope this helps.
