Old 04-03-2009, 05:42 PM
CBFD's Avatar
Default PSR-300 discriminator Tap Location
this info was attained from an email between myself and Raj Gounder <rgounder@greamerica.com>
Q: Where does one find the Discriminator Tap Point on the PSR-300?
A: On the PSR-300, "TP4" is near the top-left of the RF-PCB (when holding the
radio that the back of the radio its toward the viewer with the battery
contacts to the lower-right). TP4 is to the left of the IC that is to the
left of the two box shaped crystal filters and just below the volume/squelch
pot.
not sure if this is posted somewhere else as i could find any info other than everyone saying it has no tap location...
CBFD
Old 04-05-2009, 08:47 AM
fourthhorseman's Avatar
gre's 300 is pretty much the same as the pro97,sounds like anyway by the description of the tap location...
Old 04-05-2009, 05:02 PM
CBFD's Avatar
it's just too bad the sensitivity isn't as good as the pro-97...
Similar Threads
Pro 97 vs Pro 164 vs PSR 300 fireant Radio Shack Scanners 24 06-13-2009 11:25 AM
Newbie: Scanning software for GRE PSR 300 TimHSV Scanner Programming Software 2 12-29-2008 06:38 PM
psr 300 antenna Q-ball GRE Scanners 5 11-30-2008 10:41 AM
PSR 300 software upgrade 2alpha56 Utah Radio Discussion Forum 1 11-12-2008 08:10 PM
GRE PSR 300 vs RS PRO 164 PRO64 GRE Scanners 4 09-03-2008 07:27 PM
