Old 06-06-2009, 02:00 AM
btritch's Avatar
Send a message via MSN to btritch Send a message via Yahoo to btritch
Default Gre psr 500 help/question
I am wondering if someone might be able to help me with a question about a PSR 500 setting that I wonder if I can change.. Here Goes: On my GRE PSR 500 when I name the bank, 1 2 3 etc. and the name the frequency, When it scans and stops on a frequency, it flashes back and forth from bank name to frequency name, Is there a way to change a setting where it doesn't show the bank name when it stops on a frequency while scanning?
Thanks For Any Help You Might Be Able To Give, Thanks Again Guys!
Brian
Paragould/Greene County Arkansas 72450
Online Area Scanner Feed: http://greene.ar.scanamerica.us/
Old 06-06-2009, 04:23 AM
tobarger's Avatar
You can turn off the primary display element.
This setting will turn off the primary display element for both types of objects.
1) For trunked systems the "TSYS alpha tag" is the primary display element.
2) For conventional frequencies the "scan list alpha tag" is the primary display element.
Here we go:
PGM
F3 (GLOB)
Scroll to "LCD BlinkOn" (default should be 50)
SEL
Change value to 1 (turns off primary display element)
F1 (Save)
PSR-500
PRO-96 (returned)
Old 06-06-2009, 04:36 PM
btritch's Avatar
That is EXACTLY what I wanted!! :-) Thanks!
Brian
Similar Threads
BC396XT vs. BC396T vs. GRE PSR 500 brechtd Western Canada Radio Discussion Forum 8 04-08-2009 07:40 PM
Broke down & bought GRE PSR 500 gs_new Western Canada Radio Discussion Forum 5 12-02-2008 10:18 PM
Gre PSR 500 Desense Chevyman22360 GRE Scanners 11 10-23-2008 07:20 PM
Portable Digital Scanner Purchase - GRE PSR 500 vs RS Pro 96 vs Uniden BCD396 robo21 General Scanning Forum 9 09-29-2008 06:25 PM
My Pro 97 and GRE PSR 500 Shack Install btritch Pictures Of Your Shack/Mobile Setup 17 05-28-2008 01:21 AM
