My guess, and this is strictly a guess since I don't know of any VOC systems around here to test it with, would be that it would be hit and miss, depending on the timing of the scanner being on the control channel data stream when a voice channel grant comes through.
If it happens to be on the control channel when that grant comes through, it may pick up the voice channel. If it's not on the control channel at that point, then the voice transmission will likely be ignored as the scanner will be looking for the control channel data stream at that point.
