Old 06-10-2009, 11:34 AM
Default not receiving my conventional channels
i just used the arc 500 software to program my grepsr500 scanner for the trunking frequencies.i uploaded the conventional frequencies tha i had imputed in the night before,did an import from radioreference and uploaded everything back to the unit. now it scans the bell fleetnet system and i am receiving data,but i'm not getting anything from my conventional frequencies. any ideas?
Old 06-10-2009, 11:39 AM
Highpockets's Avatar
If they are in different scan lists you have to make sure both or all lists are enabled.
Steve
BC780xlt ~ BC785D ~ BCD996XT ~ PSR600
Old 06-10-2009, 12:06 PM
w8jjr's Avatar
Send a message via AIM to w8jjr
Just wondering if you over wrote the conv channels with the trunk channels when you imported the trunk chans. If not check what Steve says above
Jim
W8JJR
Old 06-10-2009, 12:39 PM
Default missing channels
thanks much.
when i downloaded back from the scanner to the software they were not there.so i reentered them and changed the scan list to numbers not used in the trunking part.seems to be working now.will keep my fingers crossed. thanks again
bill
Old 06-14-2009, 10:44 AM
737mech's Avatar
Default Another possibility
Take a close look at the file you are sending to the scanner from the pc. You may have priority set on for trunking, or lockout set for conventionals. I know with my 500 in my area the trunking seems to over power the conventionals. Better to sort them out into another scanlist.
In Omnia Paratus!!
BCT-15
PSR-500
Pro-2051
Similar Threads
Programming ITAC and TALK Channels Roach112683 Delaware Radio Discussion Forum 11 08-22-2008 05:13 PM
Conventional Channels 737mech Uniden Scanners 1 07-20-2008 06:24 AM
UHF/GMRS Repeater Monitoring Twister_2 General Scanning Forum 47 07-03-2008 12:45 PM
Official Uniden BC246T Scanner Thread blantonl Uniden Scanners 1140 09-28-2005 07:01 PM
The Uniden 246T: The next paradigm shift in our hobby... br0adband Uniden Scanners 3 04-29-2005 08:03 PM
