Old 06-28-2009, 06:18 PM
Question How to program trunking with gre psr 300
Hello,
I have a GRE PSR 300
Great scanner, but I have tried following the directions in the manual and cannot seem to program it correctly. Ok I am a dummy, I am in eastern Iowa and would try to program anything for Scott county or Iowa city. I would be programming in bank 3. How do I do it. I would appreciate any help or tips in doing this. Once i do it I will be fine, just need a walk through to get the hang of it.
Thanks,
jamdahay@gmail.com
Old 06-29-2009, 01:00 PM
DaveIN's Avatar
Programming is about the same as the PRO-97. Take a look at the easier to read manual:
Easier to Read Pro-97/2055 Scanner Manual
Old 06-29-2009, 02:43 PM
Halfpint's Avatar
Talking
While it may be `nice?' to know how to program your scanner manually you will find that `life' will be *a lot* easier if you pick up one of the software packages for programming it instead. I *will* admit that I might be a tad bit prejudiced towards 2 packages in particular IE: WIN97 and PSREdit300. Amazingly enough they both are great programs *and* they actually `work together' quite well with one doing some things the other doesn't and vice-a-versa. You should take advantage of both program's `trial' offering to see just which one, though I kinda suspect you'll like both because of how they do tend to compliment each other, you like and then buy that one first once the trial period closes.
Just an `Olde Fart's' 2¢ worth {VB GRIN!}
Doleo ergo sum,
Halfpint
All wiyht. Rho sritched mg kegtops awound?
Old 06-30-2009, 12:21 AM
Default grepsr300edit
I have the trial of the psr 300 edit but am unsure of how to do the tracking.
i do like the features on the program that I know how to use.
thanks to all who have responded.
Tags
iowa, programming, psr 300, trunking
Similar Threads
PSR 300 software upgrade 2alpha56 Utah Radio Discussion Forum 1 11-12-2008 09:10 PM
My Pro 97 and GRE PSR 500 Shack Install btritch Pictures Of Your Shack/Mobile Setup 17 05-28-2008 01:21 AM
Can't figure out how to program trunking on my new pro-95??? Prodrvr Louisiana Radio Discussion Forum 6 06-09-2005 05:46 PM
Trunking Protocols MaxTracker System Administration and Maintenance 3 01-25-2005 04:31 PM
Decoder for a Pocket PC Trunking Program ke7au Uniden Scanners 3 12-20-2004 11:07 PM
