Old 07-03-2009, 10:33 PM
Default GRE PSR 300 AC Adapter outputs 12 Vdc?
The voltage output of my PSR-300 AC adapter is 12.34Vdc not 9 Vdc as the adapter indicates and the manual recommends. I have been using it for about 2 years now with no problem. I'm not sure if this is normal but the scanner works fine with it. Anybody noticed this too?
Old 07-04-2009, 09:15 AM
SquierStrat's Avatar
most all AC adapters put out more volts then listed when tested with a voltmeter.
nothing unusual here.....
Old 07-04-2009, 11:21 AM
I hope you're right SquierStrat. Just curious because all the radios I have owned typically would put out + or - 10 % of the nominal output voltage. Thanks for the reply. Anybody more who owns the same scanner and adapter?
Old 07-04-2009, 12:07 PM
DickH's Avatar
Just to clarify. The reason you measure higher voltage is because there is no load (curren drain) on the power supply. If you could measure it when it is connected to your scanner (a "load"), then it should show the right voltage.
I realize most people don't care, but a little basic electronics knowledge can be very useful to scanner listeners. Basic Ohms Law and DC theory would take just an hour or two to learn.
Similar Threads
Portable Digital Scanner Purchase - GRE PSR 500 vs RS Pro 96 vs Uniden BCD396 robo21 General Scanning Forum 9 09-29-2008 06:25 PM
whats better a 2prong ac adapter or the 3prong one for 996 torontokris Uniden Scanners 0 04-10-2008 06:43 PM
help with radio shack pro 92 ac adapter stevolene Radio Shack Scanners 5 03-09-2008 04:44 PM
Any universal AC Adapter for the 996T? tomandnic Uniden Scanners 3 05-05-2007 02:12 PM
AC Adapter for BCD396T JoeH Uniden Scanners 13 10-13-2006 10:02 PM
