Originally Posted by InDICa
Hello RKG,
Thanks for clearing most of my questions up! I should have
put it more clearly.
Can I use Control channels only and pickup both Type I & Type II radio's on that system without a fleetmap being programmed? Or will I miss some transmissions on a Motorola Type IIi Hybrid system
without a fleetmap?
Can it be done? Or is it a must to have the fleetmap programmed also if only using the Control channels? Sorry I am confused with fleetmaps that are not complete.But learning day by day :-)
Thank you for your time.
For any TG block for which you do not have the correct Map parameters, you will not successfully track Type I (or Type IIi) talkgroups (i.e., those denominated as "fleet/subfleet").
Note that is true whether you use "control channel only" or not.
There are a couple of things you can do if divining the proper fleet map is important enough to warrant the effort. Control Data analyzers like "Trunker" (an older DOS-based program that is probably still available somewhere) will usually be able to construct a fleet map successfully if you let it run long enough (couple of days). Alternatively, you can simply try different size code values for a TG block that you know is active until you see which one appears to pick up traffic and reply traffic faithfully.
