Originally Posted by n0vza
Help, everything has been working fine for months. Using Win500 v1.86 with latest USB driver. I did a "download from scanner", added one convential frequency, then a "upload to scanner", and it "hangs" and displays:
PC/IF->FileSys
87% complete
Cancl
I have tried the PowerOn Quick Key sequence 0,1 to "Destructive, clears working memory and resets all Global settings to factory defaults. Does not affect V-Scanners." I have tried this a couple of times, then try uploading again - same results
Hello n0vza,
I have a PSR-500 and Win500. Also I was getting that problem
at times and found the cause was the scanner was scanning during upload to scanner. So I put it on manual and I no longer get this error.
Also good to see how much memory you have left? Too little
and found I got that error if I was too low on memory. I had way too much stuff! And 3% left of memory caused that error also,trimmed the file and that worked.
And a low power source during the upload will also cause problems.
Not sure if this will help you with your problem,but good luck!
