Originally Posted by qlajlu
I have never worked with an EDACS system and although I know it must have the frequencies in a certain order is it not possible to put the frequencies from the second EDACS system in the same System Frequencies list since you are working with objects instead of banks? That frequencies list will accept up to 32 frequencies and since both systems service the same TGs it would be like entering a second site under a Motorola 800 MHz SmartZone system.
Just asking because I really don't know.
I don't think an EDACS system will work like that.
You thoughts do bring up an interesting idea though.
Say one was lucky enough to have a multi-site edacs system that used LCN's that did not repeat from one site to the next, I wonder if it would work to put all the LCN's for two or more sites in one TSYS and then simply lock out the control channel for the site you do not want. This of course would only work if no two LCN's used the same LCN number.
I also don't know if individual frequencies for a given TSYS can be locked out in an EDACS system on the PSR-500/600. I think individual frequencies can be locked out in the Unidens but I'd have to confirm that.
I think the AmerenUE sites I'm working with may have some sites that don't have duplicate LCN's being used but I'm not sure I'm in range to test this theory.
Maybe someone else has tried this before and can confirm if it works or not.
I think it is rare to find a multi site edacs system that does not re-use LCN's across sites though so if this works then it would only apply to a very small percentage of users.
