Old 09-04-2009, 06:49 PM
Default Backlight
Need or want to have my backlight on all the time for my PSR-500 help please
Old 09-04-2009, 07:07 PM
dannyhusk's Avatar
cbro298,
If you press and hold backlight key for aprox. 5 seconds, it will stay on.
To turn off press light key once.
PSR-500 ; PRO-2018
PSR-600 ; PRO-82
PRO-106 ; BC95XLT
MIDLAND 2-WAYS
Old 09-04-2009, 07:45 PM
sjlamb's Avatar
Originally Posted by dannyhusk View Post
cbro298,
That was easy
Steve
N3VRX
BC796D - BCD396XT - BCD996XT
Old 09-04-2009, 08:29 PM
Default Backlight
Old 09-05-2009, 12:14 AM
stevecubfan's Avatar
you can also press program global then set what you want in light mode.
Old 09-05-2009, 12:45 AM
texasemt13's Avatar
Send a message via ICQ to texasemt13
If you press and hold backlight key...
Isn't this standard across 99% of scanners?
In fact, isn't this standard across 99% of backlit electronics?
EMT-B, Lab Tech
Yaesu FT-7900R, GREPSR-500, Pro-93, Pro-95, Pro-96, Pro-97, Pro-2036, Pro-2052.
Old 09-05-2009, 02:05 AM
Well, on my BCD396XT, I have to set the amount of time the backlight stays on somewhere in the settings menu. After it's set, a simple press-and-release of the power/backlight button will turn on the backlight for the time specified in the settings.
On the BCD396XT, holding the power/backlight button in is used to turn the scanner on and off.
Timothy D. Bennett/KJ4MUY
Cape Coral, Lee County, SW FL
Uniden BCD396XT, ICOM IC-706MKIIG
Old 09-05-2009, 07:22 AM
sjlamb's Avatar
Standard or not, it was a legitimate question that receieved a helpful response for the the OP. That's a good thing.
Steve
N3VRX
Old 09-15-2009, 11:07 PM
can it be set to only come on when a transmission is received?
Old 09-16-2009, 06:23 AM
Yes, but, as far as I know, not on a global basis.
GRE PSR-600 | GRE PSR-500 | RS PRO-2005 | RS PRO-39
Old 09-16-2009, 01:01 PM
what do you mean by global basis?
-Carlos
Old 09-16-2009, 07:19 PM
Please explain...very interested in this answer!
Old 09-16-2009, 10:49 PM
semo's Avatar
As far as I can tell the only way to get the backlight to come on, only during a transmission, is to enable that option for each individual user manually. I know of no quick (global) way to enable the backlight to come on for all the individual transmissions. Global just means the same setting applies to all objects in the scanner without having to manually edit each one. As stated earlier you can can enable a backlight for each received transmission, but it must be added to each object manually.
Old 09-16-2009, 10:53 PM
How is it enabled? The backlight on with transmission...
After looking, I can only assume this is a 500 thing, and not applicable to the 300/400?
Old 09-16-2009, 11:07 PM
rmiller818's Avatar
Using Win500, you can select an individual talkgroup object or highlight several, on the right under the alert area you can select backlight: on, off, or flash.
Doing it by hand, you go to program and edit (on the talkgroup you want) scroll down the menu to "Backlight:" and press the right or left arrow and it will scroll through on, off, and flash. Select the one you want and hit save. Don't know of a way to do it to more than one at once when doing it by hand.
Old 09-16-2009, 11:13 PM
semo's Avatar
When on an object or channel you want to light up - push PGM then F2 twice and then scroll down to backlight and set it to "on". Save. You will have to set each one manually or you can use software to set the backlight for each one. Setting the backlight to "flash" will cause the LCD to blink while receiving a transmission.
Old 09-17-2009, 07:57 AM
GRE500/600 only...the 300/400 don't have the "function" keys...so it doesn't help me...
Similar Threads
Pro-106 Backlight ? n8dhw Radio Shack Scanners 3 11-08-2008 06:20 PM
Updated Pro-96/2096 backlight thread OmensEdge Radio Shack Scanners 9 05-26-2007 03:03 PM
BR330T Backlight Problem click23 Uniden Scanners 2 03-13-2006 01:57 PM
Official PRO-97 Discussion Thread Voyager Radio Shack Scanners 569 10-03-2005 12:56 PM
Pro-2052 backlight adjustment? JWhipple Radio Shack Scanners 5 06-08-2005 01:10 PM
