Originally Posted by JimmyL1011
I have a bunch of GRE scanners including the GRE PSR-500 and Radio Shack Pro-97, Pro-96, Pro-2052 and Pro-2055 radios. I recently purchased a used PSR-500 and found that the antenna connector seems to be broken internally (poor signal unless you move/hold the antenna to one side) and needs a replacement keypad as the ledends have worn off.
In addition, my RS Pro-96 is sick with some type of logic problem and I was wondering if anyone knew where to send the radios to be repaired? Do the GRE-brand radios go one place and the Radio Shack models go someplace else?
I know someone out there has allllllllllllllllllllllllllllllll the answers and I'd appreciate any members who have the info.
Jim
First of all, the Pro-2052 is listed by the RR Wiki as being a Uniden built unit, the rest are products of GRE. Personally, I would drop a
trouble ticket on GRE and also one to
Uniden for the 2052 to see how they say you should handle things. You might have to register on each Web site first.
