Old 09-26-2009, 08:57 AM
K4OHO's Avatar
Send a message via AIM to K4OHO Send a message via Yahoo to K4OHO
Default New user help
I am using the PSR-600 and have never manually programmed it. Played with it a bit but have done a master reset. I noted that Radio Reference now has a feature to download to scanner programs so i thought i would give it a shot. I have downloaded the required setup to ARC500 program. I then uploaded to scanner. Once upload is done it restarts and sits there not scanning the trunked stuff as far as i can see. Do I need to press a button to begin the scan function. I have tried various with no good results.
Old 09-26-2009, 09:36 AM
I believe the imports default to scan list 1, make sure the scan list is enabled..also are in the impoerts showing in the software?, if Not, you will install the latest cable drivers from th Uniden website. Also make sure you have the latest version of the software
Paul
Old 09-26-2009, 01:42 PM
K4OHO's Avatar
I hit prog then global and scrolled down to dflt scanlist and it indicates 1. In scan lists all lists are enabled. have latest software and imports seems to be showing in software.
this is what i see in display
PGM0005 TGRP p1D the PGM alternates with ns-
Emergency Operat Hampton/ Edacs
If i press scan
I see
G
Nothing Enabled
12345678910 (is flashing)
12345678920 (is flashing)
Old 09-26-2009, 02:32 PM
qlajlu's Avatar
I don't know how ARC works, but in WIN500 the imports no longer default to a scan list. You will get the TGs and all, but you need to assign the TGs to a scan list. Just to check, press the number 1 key on the scanner's keyboard. If there are any TGs in Scan List 1 you will see it start to scan. Otherwise, you should open your programming software and check. Any TGs not in a Scan List need to be assigned or the scanner ignores them.
If you can read this, thank a teacher - If you are reading it in English, thank a veteran.
Drive no faster than your guardian angel can fly.
Time has a way to corrupt everything.
Old 09-26-2009, 05:58 PM
fmon's Avatar
If i press scan
I see
G
Nothing Enabled
If you are using Hampton VA EDACS, unzip and load this ARC500 file. Hampton is in scanlist 8 and should be default startup list.
Frank
RR Wiki Programming Shortcuts
Old 09-26-2009, 06:04 PM
fmon's Avatar
ARC requires user scanlist settings prior to import.
Frank
Old 09-26-2009, 06:30 PM
K4OHO's Avatar
Thank you very much fmon for the file it worked perfectly I uploaded it and hit scan and scanlist 8 began to scan. I also noted what was missing in my setup compare to yours in that the scanlists preview page had no info where as your has it and in your next post you mention it see.
How do I get the info to that scanlist window if I try again without your file.
Old 09-26-2009, 06:48 PM
fmon's Avatar
In Talkgrouo Objects, double click in first field under Scanlist header which should popup a dialog. Click the scanlist header which should highlight all fields. Select your desired list(s) then click elsewhere to close the scanlist dialog.
Frank
