Old 10-13-2009, 08:09 AM
K4OHO's Avatar
Send a message via AIM to K4OHO Send a message via Yahoo to K4OHO
Default PSR-500 CPU firmware upgrade question
My 500 currently has uP Boot Ver:1.1. Do I use the F10_F11_U17 or the F14_U17.exe I'm guessing the F10_F11_U17 but want to make sure.
Old 10-13-2009, 09:12 AM
fmon's Avatar
Latest is
uP Appl Ver:U1.7
DSP App Ver:U1.3
DSP Voc Ver:F1.0
Frank
RR Wiki Programming Shortcuts
Old 10-13-2009, 10:41 AM
K4OHO's Avatar
I currently have the following
uP Appl Ver:U1.6
DSP App Ver:U1.3
DSP Voc Ver:F1.0
But back to the initial question. I am not clear on which CPU patch file to use
My 500 currently has uP Boot Ver:1.1. Do I use the F10_F11_U17 or the F14_U17.exe to bring it to 1.7 I'm guessing the F10_F11_U17 but want to make sure.
Instructions state if you have 1.0 to use F10_11_17.exe and if you have 1.3 to use F14_U17.exe
Old 10-13-2009, 11:56 AM
fmon's Avatar
Use F14. In ether case the installation states no harm to the scanner.
Frank
Old 10-13-2009, 12:44 PM
K4OHO's Avatar
Well i tried the suggested one and for some odd reason it didn't see the connection during the update process, test was fine. Came back with a no data from the scanner . Please try from step 4 and scanner went back into scan mode. So I tried the other file and all is well and updated.
Old 11-10-2009, 09:38 PM
mine did the same thing as yours so I just downloaded the other one (F11) and it downloaded it and it works fine....
