Old 10-18-2009, 08:53 AM
Angry psr 300 questions
recently bought one as I heard its a great conventional/analog scanner. My questions are the following-i noticed the scanner doesnt support the i-call feature,is this right??I saw it listed on a website that it does=does software open this option up?Also,the display sometimes is blank when powered on? This cant be normal!! anyone else experience this? Do I have to return it?
Old 10-18-2009, 10:12 AM
RadMarv's Avatar
From the RR Wiki
__________________________________________________ __
GRE Scanners
The PSR-500 and 600 sets I-Call as a Private Wildcard in the menu
The PSR-300 and 400 cannot receive I-Calls
If there is a usual welcome screen text when you turn the scanner on then it would be abnormal for it to be occationally blank when turning it on.
SCANNERS = PSR-500 - PRO-106 - PRO-96 - PSR-300 - PRO-94
ANTENNAS = DIAMOND RH77CA - WATSON W-881 - ST2 - HOMEMADE WIRE
SOFTWARE = WIN97 - WIN96 - WIN500 - WIN500REMOTE_CLIENT
Old 10-19-2009, 05:07 PM
found out the answer. when doing the firmware update there must have been an error because I wasnt getting a welcome screen,just arc300 psr300 when powering on after 2 hours of occassionally turning it on the screen came back and I re-initialized the scanner and the welcome screen came back. all works fine now.
