Originally Posted by holmdt
I tried to test Same and got one peep was that what I should have heard? I fallowed the directions on page 33 and 34 of
the manual. My local freq. is 62.550 MHz. On the display it states weather 7 and it tells me that I set 2 codes. (which I did).
I suspect a typo, and the frequency you intended to type is 162.550. That is the frequency pre-programmed in to weather channel 7 of the scanner.
Also I stored the codes in storage location 1 & 2 was that ok. When same is on standby mode (FUNC + WX) how do you know when it is turned on. the screen did not change like when I turn off/on pri.
First I pressed WX. Then I pressed FUNC WX. The display shows:
(third line) FIPS:
(fourth line) SAME Standby
Did you get that? It looks very clear to me. As some have stated, although perhaps not 100% clearly, you can NOT run in WX SAME mode while in another mode, such as scanning.
The manual is clear as mud.
Actually, mud is clearer.
