Old 10-18-2009, 03:30 PM
Default Psr 500
Good Afternoon.
I all of a sudden have a problem. My 500 is telling me after down loading fres to it that "Nothing Enabled".
I have never seen this. I am running ARC500 for my programing. Am I missing somthing? Thanks guys.
Captn65
Old 10-18-2009, 03:40 PM
cfr301's Avatar
Originally Posted by Captn65 View Post
Good Afternoon.
Captn65
Eh Been there done that.. I tried uploading from the computer to the scanner, one time forgetting to click on the file first..It wiped the memory of my scanner CLEAN Go back find your file click on it reload it, hopefully thats what you did. I back up my file once in awhile just in case I screw up and delete it some how.
Old 10-18-2009, 06:53 PM
Default No Sound
Well now I have another problem it scans but no sound??? I hear the beeps fpr the buttons but no commms????
GRE PSR-500
Old 10-18-2009, 07:49 PM
cfr301's Avatar
GRE PSR-500
Did you try shutting it off waiting a few seconds then turning it back on? Try the external speaker see if you hear anything through that. Squelch set to high?
Old 10-18-2009, 08:35 PM
Astrak's Avatar
Nothing Enabled means you have no scanlists enabled or nothing assigned to scanlists you do have enabled. Try tuning the WX stations and see if you hear anything.
Maricopa county law enforcement feed
Old 10-18-2009, 10:31 PM
qlajlu's Avatar
Good Afternoon.
Captn65
"Nothing Enabled" means that you need to move a Scan List into working memory. All you need to do is press one of the number keys on the scanner's key pad. You can toggle all the Scan Lists off or on by using the number keys. Scan Lists 1 through 10 are toggled using keys 1 - 0. Scan Lists 11 through 20 are toggled using FUNC + a number key 1 - 0 (i.e. FUNC + 3 = Scan List 13).
It could also mean that you do not have any of the imported TGs or conventional frequencies assigned to a Scan List. Open your software and see if the TGs or conventional frequencies do, indeed, exist in a Scan List.
You need at least one Scan List enabled to start scanning (see illustration).
If you can read this, thank a teacher - If you are reading it in English, thank a veteran.
Drive no faster than your guardian angel can fly.
Time has a way to corrupt everything.
