Originally Posted by kifaru
Greetings Everyone!
Our local public safety is listed in the database as using a "Motorola Type II Smartzone analog and APCO-25 Common Air Interface". For a while we were able to monitor traffic on the trunked channels but recently we're only receiving fire dispatch on "conventional" channels.
We're currently using the default settings for a "MOT 800/900" TSYS. Is this the correct TSYS type based on the database listing above?
Are there other advanced settings we might need to change?
Thanks for your help!
Welcome to RR.com. It would help immensely if you would give your location and the system you are trying to monitor. Is there a possibility that the system has just undergone rebanding? I would change your trunking tables to Motorola 800 MHz Rebanded first.
I urge you to return to your
User CP (the left side of the second blue bar from the top of any page if you are logged in) and edit your profile to include your location (city and state) as you were requested to do in the material e-mailed to you when you registered. Once you fill in your location it will automatically show in each of your posts. Many of the questions you will have, and their answers, are going to be location specific and without having your location showing you will be asked over and over again what it is. So fill it in now and be done with it.
