Old 11-04-2009, 07:33 AM
Default logging methods for ohio marcs w/gre-600
A little help for the old-timer please ?
What are some of the methods that you folks are using to
log this seemingly endless list of talk groups/radio ID's ?
Using PSRedit , how do I assign a Private or Wildcard to
just one talkgroup?
Thank's a bunch for any help,
beejay
Old 11-04-2009, 08:58 AM
fmon's Avatar
Originally Posted by beejay View Post
Using PSRedit , how do I assign a Private or Wildcard to just one talkgroup?
beejay
In the TSYS right click on TG/RID header then select Add Wildcard from popup menu, leave it grayed but insure you map it to desired scanlist (default is list #1)
Do same for Pvt, but change the pulldown from Talkgroup to Private, also change scanlist as needed.
To add a known talkgroup ID to Private right click on TG/RID header then select Add Talkgroup from popup menu. Type in ID number, change to private using Pulldown. Again, remember to change scanlist if needed.
EDIT: In each of the above, click Apply button to exit:
Frank
RR Wiki Programming Shortcuts
Old 11-04-2009, 10:10 PM
thank you sir! I appreciate tha quick reply !
beejay
