Originally Posted by JRR4607
There has been a updated for the waco McLennan County TRS do i only put in the primary control channels thats what i have in now or do i put in all the alternate control channels to can some help.
I'd leave it at the four control channels (the ones in
red, also tagged with a 'c') for now. Your PSR500 doesn't need all the other frequencies, as long as you have it set for control channel only mode (and it sort of sounds like you do).
If, after a day or two, it appears that you may be missing some calls, then perhaps one of the listed control channels has been replaced by a different one. In which case, then, you may have to add all the rest of the frequencies & try to figure out what the change was. With all the frequencies, you'd catch all the calls, unless they are using a control channel not listed at all. Not likely, but remotely possible.
