Am I totally braindead? I can't find anyplace on the GRE Support site where the actual CPU Firmware update and application software update are. Anybody?
The Mode settings have 5 options. The Mode (Pwr) option controls the mode of the backlight when the scanner is being powered by the USB cable.
The Mode (Batt) setting controls the mode of the backlight when the scanner is powered by batteries. The following mode settings are available for both options:
Normal:
The backlight will normally be off unless an active channel is programmed to turn the backlight on or the power button is pressed and released.
Key:
The backlight will normally be off until either an active frequency or talkgroup turns it on, or a key is pressed. The scanner will act on the key that is pressed in this mode.
Ignore:
The same as the Key mode, except the first key press is ignored and will do nothing but turn the backlight on.
On:
The backlight will always be on, unless an active channel cause it to blink based on the alarm setting.
Stealth:
The backlight will always be off, even if an active channel has an alarm setting that would turn it on.
That feature has been in the radio since it's release. From the user manual's backlight section:
This is more of a computer problem, but when I try to update the Firmware using the GRE software, the XP computer says the scanner does not have port...and won't connect.
The computer recognizes the GRE800 scanner when I connect the usb cable...then asks to install software.
This is a netbook with no CD drive, so I downloaded the GRE software from their website.
Any help will be appreciated.
Thanks,
Bob
Good to see you can return to the last active object when scanning by pressing the left arrow on the rocker button.
