| GRE Scanners A forum for the discussion of all GRE branded scanning radios and receivers. |
11-06-2011, 6:27 PM
Pro96Com and PSR800
Mike has setup Pro96Com to work with the PSR800. It works very well, I tried it today it was nice.
J.R. N4PIZ PSR-800 now history
PRO-106
PRO-97, PRO-2067
BC560XLT, BC125AT
11-06-2011, 6:39 PM
pro96com
I got it working to. Is there a way to see all the active control channels like you can on the psr500?
11-07-2011, 12:07 PM
Good to know. I'll have to try it out.
11-07-2011, 12:16 PM
It's a little bit of a pain to get the PSR-800 to lock onto a single site though.
I set up my scanner with separate "systems" each with a single site, and an unused talkgroup to work with it. Then all I need to to is navigate to the correct site using the Browse Objects option, and press SEL to start monitoring the control channel.
11-07-2011, 12:39 PM
That's better than nothing. Thanks for adding the 800 Mike.
11-07-2011, 12:41 PM
Connection via IF out or PC/IF?
11-07-2011, 8:49 PM
PC/IF
06-04-2012, 12:43 PM
06-04-2012, 12:58 PM
So, I put in a control channel via the PSR-800 software and added an unused talk group, I enabled CC/IF dump on the settings menu on the radio.
I installed PRO96COM and it sees the radio on port8, but when I press read data from radio, I don't get anything in the signal bar meter on the bottom right of the Pro96com screen. On the radio, it's parked on the unused TG and I'm picking up the control channel and I have good signal bars and the "T" is illuminated.
Any ideas what might be wrong?
06-04-2012, 8:23 PM
I solved the issue..
11-16-2012, 7:58 PM
I have a psr800 using the pro96com but I can't get no Control Channel to sit on. What are the steps. I have found a new Freq since the radio does not decode SID or CC info. I have try to program the same freq into my 396xt that scanner won't able to pick up the freq. On the 800 I try to put P25 the T doesn't show up but when I put on Moto the T comes up.
Dell computers SUCK! Dude you jail you can't get a dell
Radios Alinco DJ-X10T IC-F43GT BCD396XT PSR-800
Youtube staugfl1991
11-17-2012, 9:07 AM
you can't find a control freq, you just need to lock on to an unused talkgroup, if you don't have one you can make a dummy tgrp.
PRO-106
PRO-97, PRO-2067
BC560XLT, BC125AT
