I'm trying to import a P25 system. The system is marked as TDMA Phase 2 because it has one talkgroup used for TDMA testing. EZ-SCAN will not import the system.
Example ...
Run EZ-Scan
Click on Library Import tab.
Select import type "By Zipcode"
Enter zip code 77002 (downtown Houston, Texas)
Set Import Categories to "All On".
Click "Import"
The "Import Complete" popup window says I have imported 8 trunked systems.
Click on the Trunked Systems tab.
The following system is nowhere to be found.
Texas Wide Area Radio Network (TxWARN) Project 25 Trunking System, Various, Texas - Scanner Frequencies
Not to confused with this system (which is correctly imported) ...
Texas Wide Area Radio Network (TxWARN) Motorola Trunking System, Metro Houston area, Texas - Scanner Frequencies
Example ...
Run EZ-Scan
Click "Import"
