  #41 (permalink)
Old 07-29-2012, 3:33 PM
troymail's Avatar
Originally Posted by nickcarr View Post
Does anyone else listen to X2-TDMA systems?
It could be just a coincidence but I just updated my PSR800 to the latest firmware and X2-TDMA audio decode sounds terrible.
It usually was rather hard to hear but it sounds worse after the upgrade.
It used to be that I would get 7/10 conversations would sound good. Now it's more like 2/10.
Can anyone else confirm?
I don't think anything changed regarding decoding of X2-TDMA. Doesn't seem any different to me.
Future PSR-900 user...(still hoping!)
PSR-800 x 2 | PSR-500
BCD-396T | BC-296D (voice) | BC-245XLT (mTrunker) | BC-600XLT | BC-IV | VX-8R
Not a Radio Shack fan.....
  #42 (permalink)
Old 07-29-2012, 4:34 PM
Send a message via AIM to buggiecar
They Also Updated the EZ Scan Software and DSP as well...
  #43 (permalink)
Old 07-30-2012, 6:45 AM
I'll second this... the Loudoun County X2-TDMA system sounds just as good to me as it did before I updated. It sounds like there may have been a DSP update that was released later (according to the person who posted just before me)... I haven't done that yet as the version check after doing the other two updates on Friday showed my DSP version was current.
Daily Use: GRE PSR-800, GRE PSR-500
KJYO Unicom Feed: Uniden BC-250D
NOAA Weather Radio KHB-36 feed: RS Pro-2052
More about my scanner feeds.
  #44 (permalink)
Old 07-30-2012, 2:07 PM
ggraves's Avatar
I just tried to update DSP and there were no new updates. I think you meant CPU.
  #45 (permalink)
Old 07-30-2012, 4:20 PM
KevinC's Avatar
Moderator
Mine sounds as good as ever also.
BC-210XLT
"Wise men speak because they have something to say; Fools because they have to say something."
  #46 (permalink)
Old 07-30-2012, 10:34 PM
Cool
Yep no worries. It was just a bad day I guess. The system sounds 1000x better today. There was a local city parade at the time so perhaps the system was just overloaded.
  #47 (permalink)
Old 08-01-2012, 9:18 AM
I noticed a new setting that wasn't documented in the changelog. It is near the bottom of the settings menu and says "Trim Logs". I can imagine that it would cut out unnecessary data from the P25 logfiles. Does anyone know about this undocumented feature?
  #48 (permalink)
Old 08-01-2012, 10:57 AM
Send a message via AIM to cookmaster Send a message via Yahoo to cookmaster
Question Trunking options,Mot Enc, Talkgroups,ED Enc Talkgroups
One new thing i notice about the new software was the abily to set it "Ignore or allow" which i take it to mean if you set it to ignore the Scanner should skip over P-25 conventonal encrypted,and or encrpyped talkgroups. I have tried it set to ignore,and allow and there no differnce in the operations of the scanner,the PSR-800 continues to stop on encrypted P-25 conventonal,and encrypted talkgroups.As anyone else experience this yet? thanks
  #49 (permalink)
Old 08-01-2012, 11:19 AM
Kel's Avatar
Kel Kel is offline
You are quite correct,I am noticing the same thing,but if you read on the EZ software tabs you will find it is just for Motorola Maud 3600 and not 9600 or P 25 conventional,doesn't help me out either in our community,maybe GRE should be aware of this.
  #50 (permalink)
Old 08-02-2012, 8:25 PM
CM1 CM1 is offline
I'm intrigued by this statement..."Add option to tune to digital and/or encrypted voice calls on EDACS systems. While the scanner will tune to those talkgroups, the scanner cannot decode the ProVoice data or decrypt an encrypted voice channel."
Can someone confirm this? You can actually track (not decode) a ProVoice talkgroup on EDACS now?
  #51 (permalink)
Old 08-02-2012, 8:41 PM
nosoup4u's Avatar
Yes, I can confirm you can track Provoice now. I have actually come across some new encrypted talkgroups on the Allentown, PA system this week with this new feature.
John - KC2KZZ
http://www.warrenskywarn.org
PSR-800, BCD996XT (w/GPS) Home Patrol-1 & BCT15
Icom IC-80AD
  #52 (permalink)
Old 08-04-2012, 7:50 AM
nosoup4u's Avatar
I am having an issue with the updated software. If I select a block of conventional channels to delete, it appears to delete the wrong ones. Anyone else seeing this issue?
John - KC2KZZ
Icom IC-80AD
  #53 (permalink)
Old 08-06-2012, 1:53 PM
Yes, I see the same thing. I select a block of five, and it deletes five -- but three are from the ones I've selected and two are from outside the original block.
  #54 (permalink)
Old 08-07-2012, 11:35 AM
So I just ordered a PSR-800. I am kind of excited about it, but I have one question. What are the odds that it will ship with the newest firmware? I have some concern about my ability to actually do an update. If something gets messed up, how easy is it to reset and start over, or do I turn this into a brick?
PM
  #55 (permalink)
Old 08-09-2012, 10:56 PM
John599nj's Avatar
Something always goes wrong when I update the scanner. Operator error I hate change lol.
GRE PSR 800 Yaesu Ft 7900 Kenwood TS 450s
QJE Switching Power Supply
Joe Walsh Analog Man
  #56 (permalink)
Old 08-10-2012, 8:24 PM
pak715's Avatar
I just purchased the 800 and it seems like it will be somewhat challenging ?
  #57 (permalink)
Old 08-11-2012, 4:36 PM
The only thing I have noticed since updating is intermittent problems with decoding RID's off of P-25 systems. Before the update it would decode ID's all the time but now seems to be intermittent even with a solid signal and the T flashing.
Dave Williams-N8DHW
Middletown, Ohio
  #58 (permalink)
Old 08-16-2012, 2:44 PM
I agree completely. Before the update, mine was working great. Afterwards, I immediately noticed that it wasn't reading IDs as well.
  #59 (permalink)
Old 08-16-2012, 3:10 PM
scannerfreak's Avatar
Moderator
I haven't seen any issue with RID's on either Motorola or P25 systems. It displays the RID every time on the two P25 systems I monitor. Not saying there isn't an issue, just saying it's not happening on my two PSR 800's.
Forum Rules and Guidelines
  #60 (permalink)
Old 08-18-2012, 4:21 PM
nosoup4u's Avatar
I noticed the same thing. I probably see a 50% reduction in the radio Id's that get shown on all the systems I monitor.
John - KC2KZZ
Icom IC-80AD
