Old 10-05-2012, 10:47 PM
tampatracker's Avatar
Default EZScan programming error message.
While doing some routine maintenance on one of my V folders in my PSR 800, ( I was changing the delay times for groups of TGID's, 30 to 45 at a time tops) I was presented with the following error message ; "Access violation at address 00498C8f in module 'EZScanDG.exe.' Read of address 00000001." As far as I can tell the software completed the original task I had set for it with no corruption of any other field of data that were there originally. I've searched the forum for any question like this with no luck, so I decided to ask it here before submitting a ticket to GRE about it. Anyone else seen this too?
Uniden 396XT, PSR-800 x2 , PSR-500, BC 250D, BC 245XLT, YAESU FRG-8800. Using Freescan and PSREdit500.
Old 10-08-2012, 11:44 AM
jamesa53's Avatar
Mine just quits with the "Not Responding" message randomly....
PSR-800 (EZScan)--PRO106 (Win500)--PRO197 (Win500)--PRO96 (Win96)--PRO2096 (Win96)--PRO92 (Plain model) (Win92)--PRO90 (Keypad)--BC210XLT (Keypad)--BC100XLT (Keypad)-PRO-4 (Xtals)
Old 10-09-2012, 5:39 PM
I've had similar errors while EZScan is retrieving the list of audio recordings from a card or scanner memory.
Old 10-09-2012, 6:05 PM
mike_s104's Avatar
What OS are you running it with and what version of the software?
Old 10-09-2012, 7:58 PM
I have this problem quite consistently on both Windows 8 and Windows 7 both 64 bit.
Until I click "Ok" or whatever it is, the progress halts, but after it resumes and works just fine.
Old 10-10-2012, 10:29 AM
I get this error with windows XP 32 bit. I am running the latest version the EZscan software.
