| GRE Scanners A forum for the discussion of all GRE branded scanning radios and receivers. |
11-04-2012, 12:48 AM
psr 800 question
I was thinking getting the the psr800. But I have a few questions about it. Am I able to charge the batteries while the radio is turn on? Also on the CC Dump. Example> 855.1125 c01 856.2125 c03 857.0125 c04 etc... When I had the psr500 I got the Edacs LNC correct on the CC. I see scannermaster is sold out for now.
Dell computers SUCK! Dude you jail you can't get a dell
Radios Alinco DJ-X10T IC-F43GT BCD396XT PSR-800
Youtube staugfl1991
11-04-2012, 7:18 AM
1) no the batteries don''t charge while the scanner is on
2) I don't know about the CC info you want.
3) Try http://www.aesham.com/ Amatuer Electronics , That's where I got my 800 from.
11-04-2012, 10:47 PM
PSR 800 Ham Radio Outlet $399.95 shipped.
11-09-2012, 2:31 PM
I looked at the Freq range on the 700mhz on the 800 starts from 764.000 but on the bcd396xt starts from 758.000mhz that is a big difference wonder why? I ordered the 800 today should be here Mon or Tues. Got it from Ham Radio Outlet
Youtube staugfl1991
11-10-2012, 3:49 PM
The radio be here Monday. If I buy a ac charger will I am able to have the radio on and charge the batteries?
Youtube staugfl1991
11-10-2012, 4:19 PM
The radio is powered and can be programmed via the provided USB cable. You do not need an external power cord. Powered off, the cable will allow charging the batteries but most users do not recommend doing that. Use an external battery charger instead.
Future PSR-900 user...(still hoping!)
PSR-800 x 2 | PSR-500
BCD-396T | BC-296D (voice) | BC-245XLT (mTrunker) | BC-600XLT | BC-IV | VX-8R
Not a Radio Shack fan.....
11-11-2012, 4:01 AM
I forgot to ask this too I know the psr-500 it has connect tone option on it. Does the psr-800 have it?
Youtube staugfl1991
11-11-2012, 1:36 PM
I can't see using a $500 dollar scanner to charge a $15.00 set of batteries that could easily leak when charging ---thus ruining a $500 radio.
I'll buy a $25.00 charger to do that & do a much better job
BUT that is me and my opinion-------which is worth exactly what you paid for it
11-11-2012, 2:47 PM
I have a set of batteries I have get more since I have only 4. If I just want to power up rhe radio without batteries am I able to do that without going through the computer?
Youtube staugfl1991
11-11-2012, 2:54 PM
I don't know of any scanner that utilizes connect tones. Including the PSR500.
11-11-2012, 3:14 PM
When I had the psr500 you go to the control channel it shows the connect tone and sysid.
Youtube staugfl1991
11-11-2012, 3:48 PM
Location: High atop the redwoods of Venus & slightly NE of the People's Republic of Firestone!
If you are talking about NAC `tones'/`codes' used by P25 `conventional' systems, yes the PSR-800 has the ability to find and use them.
Doleo ergo sum,
Halfpint
Show me a piano falling down a mineshaft and I'll show you A-flat miner.
11-11-2012, 8:59 PM
Yes.........................any AC powered USB outlet will power the unit even if there is no batteries in the unit
11-12-2012, 1:53 AM
The connect tone is for trunking system.
Youtube staugfl1991
11-12-2012, 2:08 AM
and is not used by scanners.
11-14-2012, 8:54 PM
I see the recording does not record the tone when the station gets paged out. It will record the audio.
Youtube staugfl1991
11-15-2012, 3:24 AM
You mean pager alert tones or tone codes?
If pager tones, it sounds like the tones are being sent on a different frequency so you;d need to capture and record that too.
11-16-2012, 2:40 AM
Its on the same Freq (channel) doesn't record the 2 tone page but when dispatcher comes on it will record that.
Youtube staugfl1991
11-16-2012, 3:27 AM
I've recorded dispatch on my systems and the tone isn't treated and differently than any other audio on a given channel that is being recorded -- it records tones and voice for me.
What system/frequency are you trying to record?
11-16-2012, 6:25 PM
VHF they page out tone(s) for the stations dispatcher comes on it did record for 2 seconds than stops back recording for 2 seconds.
Youtube staugfl1991
