Old 12-07-2012, 9:29 AM
Default Signal Strength Bar settings
With the PSR-500, the received signal strength bar settings can be customized.
For example, I have one bar = 440, five bars = 750.
How do you set the signal strength bar settings for the PSR-800?
I'd like to compare the sensitivity of the PSR-500, Pro-106 and PSR-800.
(My Pro-106 seems to be more sensitive than my PSR-500, based on the bars.)
Old 12-10-2012, 3:21 AM
Halfpint's Avatar
Location: High atop the redwoods of Venus & slightly NE of the People's Republic of Firestone!
Unfortunately you can not `adjust' the signal strength indicators' levels like one can do with the 500/600s.
Doleo ergo sum,
Halfpint
Show me a piano falling down a mineshaft and I'll show you A-flat miner.
Old 12-11-2012, 7:50 AM
how do i find the signal strength settings in the menu? i never heard of it before,want to check it out.thanks.
Old 12-11-2012, 8:06 AM
Unless you have a calibrated signal generator of some type, you won't be able to adjust the "S-Meter" settings and use it to compare receiver sensitive.
Old 12-11-2012, 8:37 AM
In Win500, the RSSI Bar Threshold settings are at the bottom left of the Extended Settings tab.
I'm not sure that you can change those without using a program like Win500.
Old 12-14-2012, 11:14 AM
Has anyone ever done that?
Is there a published listing of the RSSI values that correspond to the bar settings in the PSR-800?
If I can't set the PSR-800 to correspond to my PSR-500 settings, maybe I could do the opposite.
