Old 12-08-2012, 10:56 AM
de784's Avatar
Default psr wont update
was trying to update 800 with cpu and dsp update beta updates the dsp went fine but when I try cpu error comes up that it is not receiving info from scanner and I'm missing a process
pro 83
(2) Pro 96
pro 97
psr500
pro 2022
pro 164
Old 12-08-2012, 2:52 PM
troymail's Avatar
DSP is easier and more straight forward than the CPU. For the CPU, you need to make sure and follow the directions very closely...
Here's what I do:
Plug the USB into the PC.
With the radio off, press and hold the MENU button.
Insert the connector into the side of the radio
The radio should display version info and saying something like "waiting for USB..."
Start EZ Scan and do the CPU update.
Future PSR-900 user...(still hoping!)
PSR-800 x 2 | PSR-500
BCD-396T | BC-296D (voice) | BC-245XLT (mTrunker) | BC-600XLT | BC-IV | VX-8R
Not a Radio Shack fan.....
Old 12-08-2012, 3:30 PM
de784's Avatar
Wirelessly posted (Mozilla/5.0 (Linux; U; Android 4.0.4; en-us; DROID RAZR 4G Build/6.7.2-180_DHD-16_M4-31) AppleWebKit/534.30 (KHTML, like Gecko) Version/4.0 Mobile Safari/534.30)
Did that but when i try to load file from gre it says no data from scanner
pro 83
(2) Pro 96
pro 97
psr500
pro 2022
pro 164
Old 12-08-2012, 5:01 PM
troymail's Avatar
I've actually seen something like this before - I usually try a different USB port .. and if that doesn't work I then reboot and it starts working... May not work for you but that's what I do.
Old 12-08-2012, 5:15 PM
Kingmobileaudio's Avatar
Send a message via AIM to Kingmobileaudio Send a message via MSN to Kingmobileaudio Send a message via Yahoo to Kingmobileaudio Send a message via Skype™ to Kingmobileaudio
What operating system are you running? Maybe the drivers are not installed?
Sent from my iPhone 5 using Tapatalk
(402) 937-8578
Old 12-08-2012, 5:16 PM
de784's Avatar
Rebooted everything working. Thanks
pro 83
(2) Pro 96
pro 97
psr500
pro 2022
pro 164
